997 : 2004- 60
996 : 1997-2005 29
Boxster : 1997- 26
PostPosted: Sun Sep 08, 2019 5:36 am    Post subject: FS: Center Console for 997 ----------------- Reply with quote
Hi, i have a spare center console for sale, good for colour code painting or to retrim in leather/alcantara etc, comes bare with only cigarette 12v socket attached.
£40. Located in London..
J Smile
 Filesize:  1.66 MB
 Viewed:  1018 Time(s)
 Filesize:  1.66 MB
 Filesize:  1.7 MB
 Filesize:  1.35 MB
PostPosted: Sun Sep 08, 2019 10:15 am    Post subject: Reply with quote
Worth clarifying that its for a convertible unless you fill the roof button hole.
Hint: this will also fit a 987.1 Wink
It will fit a 987.2 BUT you will either need to source a .1 roof button (plug and play into existing harness) or widen the button hole (I used a .1 button as I think they are better)
May be worth you also posting up on Boxa.net Thumb
Hertsdriver
2004 Porsche 997 Carrera 2
PostPosted: Mon Sep 09, 2019 9:05 am    Post subject: Reply with quote
Thats a coupe console... no roof switch hole.... Thumb
PostPosted: Mon Sep 09, 2019 3:49 pm    Post subject: Reply with quote
I can see a roof switch hole, or at least its the hole for a switch on the 987.1 which uses the same console Dont know
Ie on the “downslope” between the handbrake and cigarette lighter
Hertsdriver
PostPosted: Tue Sep 10, 2019 9:16 am    Post subject: Reply with quote
thats not where a 997 switch goes (it goes on the flat section in front of the ash tray, you can see a casting mark for it on the underneath shot) all 997's come with a blanking plug for the bit you are talking about, so any 997 owner would already have that bit Thumb
PostPosted: Tue Sep 10, 2019 10:57 am    Post subject: Reply with quote
Ah OK, so its not for a converatbile 997 but it will fit a 987.1 boxster ie the hole is there for the roof switch and it will also fit a 987.2 boxster if you either source a 987.1 switch or widen to the hole to fit a 987.2 switch Thumb
Strange that it has the hole for a 987 boxster roof switch cut out which has a blanking plate but not the hole for a 997 roof switch (I did not realise the roof switches where in different locations 997-987)
Hertsdriver
PostPosted: Tue Sep 10, 2019 11:16 am    Post subject: Reply with quote
Actually, I am talking out of my ar$e! Floor
The bit I'm talking about is the passenger airbag warning light on a 997.2 , you are 100% correct Jon Thumb
Can I ***** up this for sale thread any more? Dont know Laughing sorry!
