991 : 2011- 18
997 : 2004- 80
996 : 1997-2005 33
Boxster : 1997- 25
TheCock
1996 Porsche 993 Carrera 2S
PostPosted: Fri Sep 06, 2019 10:22 pm    Post subject: New discs and pads - advice please Reply with quote
Hi all, need discs and pads all round on 2010 997.2 Carrera, 29k miles, lowered springs and cross pipes. Not tracking it, just normal fast road stuff.
Porsche want £2k all round.
So comments on what you’ve done or even if the OEM is a good route is welcomed.
Ta
2010 997.2 Carrera, Aqua Blue
1996 993 Carrera S, Vesuvius with Steel Grey
1994 968 Sport, Slate Grey
PostPosted: Fri Sep 06, 2019 10:31 pm    Post subject: Reply with quote
Go on carparts4less.co.uk Wang your reg plate in, search for discs and pads, look at the options, then purchase what you fancy, don't forget to enter their discount code on their home page banner. Will be around £500 for the lot tops. Pagid are usually the known preferred budget ones but they're all mostly similar.
Then bob down to your local garage and ask them to whack them on or DIY. thumbsup
Norfolk & Idea
PostPosted: Sat Sep 07, 2019 8:06 am    Post subject: Reply with quote
Nice one. Thanks Thumb
2012 997.2 Turbo Basalt Black. Bit of a 9E ing.
2008 Ducati 1098R (Track)
2016 Macan GTS
2019 Vito119 CDI Sport- Household Star!
2018 Ducati Panigale V4S (Track)
jonno_
2005 Porsche 997 Carrera 2S
PostPosted: Sat Sep 07, 2019 10:36 am    Post subject: Reply with quote
If its not mega urgent, also check autodoc for prices - even better value but took about a week to arrive.
I went with new brembo discs, pads anti-rattle shims and wear sensors, Brembo hats/bells have a very effective anti- rust finish.
takeflight
PostPosted: Sat Sep 07, 2019 4:09 pm    Post subject: Reply with quote
Gsf autoparts use their 60 percent code, relative easy job plenty of YouTube how tos.
easternjets
Watkins Glen
PostPosted: Sat Sep 07, 2019 4:42 pm    Post subject: Reply with quote
Beware with Autodoc, I've used them quite a lot recently and they have a small charge at the end of the order, which is optional although it defaults to it, saying that there is a no quibble returns policy!
Well it ain't no quibble, I bought a pair of Metzger brake discs for my Boxster, took them to the garage and they wouldn't fit. Checked and double checked the part number, make model etc and Autodoc blamed me saying I'd ordered the wrong ones but I hadn't, the numbers matched but the discs wouldn't go on due to a ridge on the inside of the disc.
Eventually after lots of checking and arguing they very begrudgingly agreed to take them back and refund me.
I normally wait for ECP to have a 'one off' special sale event and buy them then, the last discs I got which I think were Pagid had the same stamps as the ones I took off, they fitted perfect and with new pads worked out about £200. It's a pretty easy DIY job, certainly easier than a flippin Honda Jazz that I did the week before!
You will need a 10mm hex key, if you have that your good to go.
Also get the sensors as they inevitably crumble when you try to pick them out.
997 Turbo Gen 2
997 Turbo Tiptronic S
Porsche 968 Coupe 1992
Porsche 928 S4
Porsche 911 3.2 Carrera 1985
BlackTurbo
PostPosted: Sun Sep 08, 2019 10:50 am    Post subject: Reply with quote
on this topic, does anyone actually have a definitive view on which discs and pads are actually the OEM equivalent to Porsche. I would assume that whilst you can save money going to ECP or GSF etc, anyone with an OPC Warranty running would probably want to keep to OEM just to avoid any problems with claims down the line (e.g. if the calipers gave up could an OPC turn around and say the brakes are non-OEM from looking at markings and deny the claim).
easternjets
Watkins Glen
PostPosted: Sun Sep 08, 2019 11:44 am    Post subject: Reply with quote
I'm pretty sure that they use Pagid pads as do VW.
Not sure about the discs.
997 Turbo Gen 2
Porsche 928 S4
Billy Bumpsteer
PostPosted: Sun Sep 08, 2019 12:33 pm    Post subject: Reply with quote
997 pads from Porsche are Textar, they wont have the Porsche logo or number on them but should be good for warranty. Discs are SHW and only available through OPC. Would they pick up on Pagid or Sebro discs fitted if you had a warranty? Probably not but is it worth the risk?
Norfolk & Idea
PostPosted: Sun Sep 08, 2019 3:49 pm    Post subject: Reply with quote
Fekin right they would! I know a guy who changed the pads on his GT-3 (under OPC warranty) and his OPC pulled him on the grease/lube he'd used around the caliper piston seals. It wasn't Porsche approved grease apparently, ffs Rolling Eyes
2016 Macan GTS
BlackTurbo
PostPosted: Tue Sep 10, 2019 9:12 pm    Post subject: Reply with quote
That's nuts..did they deny his claim as a result?
Seems there are various views on what actually are the OEM discs and pads just from the few responses on this thread so probably goes to show it is a bit of a gamble I guess if you have a warranty and go outside of the network for parts.
Norfolk & Idea
PostPosted: Wed Sep 11, 2019 4:39 am    Post subject: Reply with quote
No. He was in for something unrelated, not warranty work. But they picked up on it and gave him the heads up.
2016 Macan GTS
Billy Bumpsteer
PostPosted: Wed Sep 11, 2019 7:42 am    Post subject: Reply with quote
Textar & SHW no ifs, no buts
Seventy Seven
PostPosted: Mon Sep 16, 2019 10:15 am    Post subject: Reply with quote
Found some good prices on the links provided.
However, been talking to a few local Indy’s and they have recommended Brembo or Textar.
One said Brembo discs with Textar pads, as Brembo pads can be squeaky....?
The other said he can do either for the front, fitted for £445 all in!
Any advice re the above? Go both Brembo or both Textar; or mix as above?
Current:
997.2 C2S, Meteor Grey, PDK (with paddles), PSE, Sports Chrono, etc.... (2009)
Range Rover Evoque, Dynamic Lux, Black (2015)
boardingnath997
PostPosted: Mon Sep 16, 2019 7:43 pm    Post subject: Reply with quote
I went with the OE options (textar and Sebro) and they squeal on and off so I wouldn’t guarantee that any brand doesn’t have the potential to squeal
2009, 997.2 Carrera S PDK
C4Silver
PostPosted: Mon Sep 16, 2019 7:47 pm    Post subject: Reply with quote
Lee997
PostPosted: Tue Sep 17, 2019 9:31 pm    Post subject: Reply with quote
I would expect disks to be consumable parts sakes as pads which are all not covered by warranty! Meaning you won’t breach warranty replacing them with another make!
2k for 4x disks and pads is absurd ?
I changed front pads on 2different cars today, Landrover sport 2016 and an Audi Rs4 2017, both sets came in less than £100.
Rgds Lee.
Billy Bumpsteer
PostPosted: Wed Sep 18, 2019 6:58 am    Post subject: Reply with quote
Rgds Lee.
Not with the Porsche warranty.................... Hand In fact I doubt any manufacturers warranty. Say a cheap set of Chinese pads break up and destroyed a caliper which went on to do some more damage, you're saying it would be covered?
PostPosted: Wed Sep 18, 2019 7:51 am    Post subject: Reply with quote
A warranty claim for an unrelated failure wouldn't be affected but you wouldn't be able to renew the warranty as it would fail the 111 point check.
Seventy Seven
PostPosted: Fri Sep 20, 2019 8:46 am    Post subject: Reply with quote
Any views on this please?
Also, just spoke to a non-Porsche Indy who said use OEM parts, Brembo and Textar are inferior to OEM as aftermarket - is this correct?
Current:
