991 : 2011- 18
997 : 2004- 80
996 : 1997-2005 33
Boxster : 1997- 25
Lee997
PostPosted: Fri Sep 06, 2019 5:57 pm    Post subject: Gearbox issue. Reply with quote
im suspecting the gearbox brain circuit board is playing up in my 997.1. Anyone know where I can source one?
Lee.
jonno_
2005 Porsche 997 Carrera 2S
PostPosted: Sat Sep 07, 2019 10:42 am    Post subject: Reply with quote
Hello Lee
Think we're going to need more info here.
What is the fault & fault code?
Proper diagnosis needed or you'll gradually replace parts till fault is fixed.
Assume its a tip - if so, its a MB unit, so plenty of parts and knowledge there.
Lee997
PostPosted: Sat Sep 07, 2019 6:20 pm    Post subject: Reply with quote
Hi Jonno,
Couple of months back I gave it a large amount of right foot while right hand round a roundabout, the gear indicator started alternating between D & N car went into limp mode and warning came up in main instrument showing a red rectangle box with two circles in it with the warning triptronic overrun.
After turning off and restarting fault cleared, although I did replicate the fault out of curiosity?
It’s behaved since ( although I’m not sure I’ve put it under the same stress since)!
week or two ago while on a road trip of a few hundreds miles on a very hot day, I accelerated heavily and the gear indicator went out (no gear selected) I immediately dropped the throttle waited a few seconds and it found gear again.
I’ve discussed with a local Indi, who recon it’s the contacts on the circuit board work loose after time and replacing the board would fix it! Although after trying they state porsche no longer sell the board but will look around for me?
Lee.
easternjets
Watkins Glen
PostPosted: Sat Sep 07, 2019 10:19 pm    Post subject: Reply with quote
Do you have the part number or a description of the part?
I can give a guy a ring on Monday morning to see if he has one.
997 Turbo Gen 2
997 Turbo Tiptronic S
Porsche 968 Coupe 1992
Porsche 928 S4
Porsche 911 3.2 Carrera 1985
Lee997
PostPosted: Sun Sep 08, 2019 8:20 am    Post subject: Reply with quote
I’m just taking it from what my local indi told me re- there being a board in the box (from underneath the car) it’s above the solenoid tray, apparently known for this error and causing problems. The contacts work loose?
Not seen it or had it out, can’t find a listing on regular parts sites?
