991 : 2011- 18
997 : 2004- 80
996 : 1997-2005 33
Boxster : 1997- 25
Drew1209
PostPosted: Fri Sep 06, 2019 3:51 pm    Post subject: Steering wheel removal Reply with quote
I’ve had a search on the subject and couldn’t really see what I was looking for.
Now to remove the airbag I read that the battery has to be disconnected for 30mins approx, I am right in saying before I disconnect the battery I should turn on the ignition to stop alarm going off ?
If that is the case do I leave the keys in the ignition until I reconnect the battery with the new wheel fitted ?
pzero
PostPosted: Fri Sep 06, 2019 4:04 pm    Post subject: Re: Steering wheel removal Reply with quote
http://www.911uk.com/viewtopic.php?p=725080
991.1 Carrera GTS
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Fri Sep 06, 2019 5:24 pm    Post subject: Re: Steering wheel removal Reply with quote
No just for when you remove or re-attached the battery terminals.
PostPosted: Fri Sep 06, 2019 7:43 pm    Post subject: Reply with quote
i'll just clarify ..
Ignition on .. lights on dash illuminated .. disconnect the battery earth lead .. wait 10 mins then remove the airbag and steering wheel .. refit with new .
Reconnect the battery negative lead ( earth lead ) ... turn off ignition as its job done .
Drew1209
PostPosted: Fri Sep 06, 2019 7:53 pm    Post subject: Reply with quote
Thanks for the help guys. I’ve got the airbag separated from the wheel now but I can seem to get the connector out that holds the bag to the wheel, is there a technique to this, tried giving it a pull but no joy
PostPosted: Fri Sep 06, 2019 8:01 pm    Post subject: Reply with quote
https://www.pelicanparts.com/techarticles/Porsche-996-997-Carrera/62-SUSPEN-Steering_Wheel_Replacement/62-SUSPEN-Steering_Wheel_Replacement.htm
