991 : 2011- 19
997 : 2004- 76
996 : 1997-2005 35
993 : 1993-1998 7
Cayenne : 2003- 4
Geezer 911
PostPosted: Thu Sep 05, 2019 7:25 am    Post subject: How to replace drive belt? Reply with quote
Hi all/(Dermot/Iain)
Quick question? How much should I be paying to replace a drive belt? I have just been given a quote of £85x2 hours not including parts.
MarkGolf
PostPosted: Thu Sep 05, 2019 8:19 am    Post subject: Reply with quote
I could do it with my eyes shut in a casual 20 mins.
A vid I just found, on a 996 but it's the same.
https://www.youtube.com/watch?v=hXxYDJ4Rfa4
I'd expect an hours labour MAX when being charged at a garage.
Current fleet
1991 964 Carrera
2005 997 Carrera S
2008 957 Cayenne GTS
2003 Boxster 2.7
1991 Mercedes 500SL
1979 Mercedes 280e
1995 VW Golf VR6 3.0
Hertsdriver
2004 Porsche 997 Carrera 2
PostPosted: Thu Sep 05, 2019 8:22 am    Post subject: Reply with quote
If you are even remotely competent with a screwdriver you can do it yourself... takes about 10 minutes tops. Belt cost me £16 from carpartsforless.com (Made by Continental).
Open Youtube Page
Geezer 911
PostPosted: Thu Sep 05, 2019 10:31 am    Post subject: Reply with quote
thanks for the resposnes so far
I rushed typing in the subject on my way into work it was supposed to say how
much should it cost?
I have been advised as my car is a Gen 2 997, to replace a drive belt on this model we will have to remove the rear lights and rear bumper to get to a bolt that allows the belt to be removed. For this acharge 2 hours @ £85.00 per hour excluding parts.
I was wondering if that was accurate?
pzero
PostPosted: Thu Sep 05, 2019 11:41 am    Post subject: Reply with quote
https://youtu.be/BQhfcdQf1QA
There is a quicker method, but more related to the 911's older cousins.
991.1 Carrera GTS
Windy101
PostPosted: Thu Sep 05, 2019 12:46 pm    Post subject: Reply with quote
That is not accurate. All you have to do is remove the airbox.
PJ997
PostPosted: Thu Sep 05, 2019 2:21 pm    Post subject: Reply with quote
Whoever does it . . . . check the tensioner isn't seized.
Hertsdriver
PostPosted: Thu Sep 05, 2019 2:36 pm    Post subject: Reply with quote
Surprised Surprised Surprised Surprised Surprised
Floor
P9XX
PostPosted: Thu Sep 05, 2019 4:23 pm    Post subject: Reply with quote
Geezer 911: It's not necessary to remove rear lights and bumper to replace the aux belt on a 997.2 There's a hole in the bumper skin behind the number plate to help with replacement of the belt.
Here's how :-
https://www.youtube.com/watch?v=Vjxd5sa65I0
Whoever does the job must check to see if the belt tensioner works properly.
See this thread:-
http://911uk.com/viewtopic.php?t=132158&postdays=0&postorder=asc&start=0
2008 997.2 C2S PDK Basalt Black
PostPosted: Thu Sep 05, 2019 5:48 pm    Post subject: Reply with quote
Shall we just say .. i think the quoting garage made a mistake and leave it at that .
First picture on the above link ( previous post ) shows you the spacer and bolt that needs removing .
As P9XX has said .. there is a hole behind the number plate to gain access and so a PU/Bumper removal is not required .
As a stand alone job then its 0.6 - 0.7 hrs labour i would guess at .
Geezer 911
PostPosted: Thu Sep 05, 2019 7:18 pm    Post subject: Reply with quote
Every one thank you for the advise it all makes perfect sense.
I’m disappointed with this Indy I spent alot of money with them in my 911 ownership. Frustrating I have to research a job for them.
Cheers again
