991 : 2011- 18
997 : 2004- 80
996 : 1997-2005 33
Boxster : 1997- 25
coullstar
PostPosted: Wed Sep 04, 2019 9:50 pm    Post subject: Coilover check / rebuild Reply with quote
Any good companies to use for a coilover rebuild / check?
Bought some 2nd hand KW1's that appear in great condition however I think one shock is compressing a lot easier than the others.
Just wondering if its worth getting them checked and it rebuilt or just send them back.
Marky911
PostPosted: Wed Sep 04, 2019 11:59 pm    Post subject: Reply with quote
Hi Graham,
They’re generally manufacturer specific so Bilstein rebuild Bilsteins etc.
KW have a UK centre but take your lube and don’t be in a hurry. Very Happy
The V3s on my old C2 went for a rebuild when Craig had them. Same as you, one front one was slower to rebound than the rest. £450 for the pair of fronts to be rebuilt.
Again they aren’t cheap to deal with and they don’t rush. Craig rang up after a week or so to see where his were and the guy says “Oh yes, they’re starting them this week”. It was 3 or 4 weeks in total the car was off the road.
Bilsteins UK centre is much better by comparison. It used to be just £85 + vat per corner to have a Billie refurbed.
That’s why I always say if I was buying new I’d buy Bilsteins for better aftercare or Ohlins for better adjustment. KWs are great when they’re working and not leaking, but expensive to overhaul. Thumb
I got Craig’s C2 ones cheap though thanks to him and my current ones were on the car when I bought it. If I needed all 4 rebuilt in the future though for £1000, I’d consider paying the extra to change to something else.
Oh one last point, maybe V1s will be a bit cheaper to rebuild than the V3s due to having less adjustment etc. Wishful thinking maybe, but worth asking.
coullstar
PostPosted: Thu Sep 05, 2019 6:07 am    Post subject: Reply with quote
This is what I had feared. I have one place to phone today as well to see. Even if it cost me around £200 to fix I'm still better off.
This is what I got, top mounts included as well.
 Filesize:  336.11 KB
 Viewed:  896 Time(s)
jond58
PostPosted: Thu Sep 05, 2019 7:14 am    Post subject: Reply with quote
Reactive suspension near York will give you some good advice
crash7
PostPosted: Thu Sep 05, 2019 7:24 am    Post subject: Reply with quote
Try Ian Gardiner, he rebuilt my JRZ's and I know Gravity Center also use him.
http://www.igracing.co.uk/index.html
coullstar
PostPosted: Thu Sep 05, 2019 8:20 am    Post subject: Reply with quote
Phoned these guys - helpful and KW motorsport rep.
http://www.corneringforce.com/
£120 to test all 4 with print out. Then looking at £132 for rebuild if needed. Might work for me.
Marky911
PostPosted: Thu Sep 05, 2019 8:29 am    Post subject: Reply with quote
Sounds like a bargain. Watching with interest. Thumb
coullstar
PostPosted: Thu Sep 05, 2019 9:04 am    Post subject: Reply with quote
Basically I have £600 to play with before it would have been better with new. The car they came from was water damage so not involved in a crash.
OR just return then get a brand new set of shocks and springs for no extra cost but then Im fixed on ride height. I was super impressed by the KW1's I had on my RS4 in terms of rdie and they lasted 30k no problems so I think Im going to send these for testing then see.
Will report back.
coullstar
PostPosted: Mon Sep 16, 2019 2:36 pm    Post subject: Reply with quote
So got some feedback - one damper is as expected not performing right so that needs work.
The guys at cornering force cannot do the work on these so I contacted KW themselves with part numbers.
Its a rear that's not functioning right so KW are offering two new rear dampers at £360 which I thought was very good. They admitted a rebuild would be more.
So all in including the inspection, tops mounts and two brand new rears I will be £1500 for a set of coilovers ready to fit.
If I send them back Im loosing £200 straight off for shipping and inspection. Therefore if I get me money back and go Koni/H&R route inc new top mounts that will be about £1450 all in.
Bit of a dilemma but Im swaying towards continuing with the KW's for the height adjustability aspect.
maldren
PostPosted: Tue Sep 17, 2019 9:04 am    Post subject: Reply with quote
In a just over week's time we will have had our suspension comparison day at Bruntingthorpe including KW3s and Konis. I'll keep everyone posted on results.
Mike
Mike
coullstar
PostPosted: Tue Sep 17, 2019 12:52 pm    Post subject: Reply with quote
Ive just gone with the two new dampers route.
I don't have £2k to spend, £1500 was my limit so figured Id like to get the adjustability in ride height from the KW's with effectively the same price as fixed ride height. I'll watch with interest.
Marky911
PostPosted: Thu Sep 19, 2019 6:22 am    Post subject: Reply with quote
Good move. Definitely worth sticking with the KWs, especially at that price for two new ones.
If I want any work done on mine I’ll do as I was going to then and deal with KW, as the place in Harrogate aren’t much use if they can’t rebuild them.
KW will test them etc hence it’s cutting out the middle man.
Thanks for the update Graham. Thumb
crash7
PostPosted: Thu Sep 19, 2019 9:06 am    Post subject: Reply with quote
I run KWV1 on my 964, granted I do not cover much mileage in the car, however thus far I have been impressed.
The spring rates are higher than some of their competitors, Bilstien et el, however the damping is good and the car rides well.
In addition to coilovers being height adjustable they look so much better Grin - Definitely stick with them Thumb
