991 : 2011- 18
997 : 2004- 80
996 : 1997-2005 33
Boxster : 1997- 25
sp1ke
PostPosted: Wed Sep 04, 2019 8:03 pm    Post subject: where I can buy these centre caps for Fuchs replicas? Reply with quote
As per the title, I'm looking for some centre caps like the one in the picture.
Preferably with a coloured crest, but failing that I'd settle for black crests.
I've tried the usual suspects, but not seen any like these, so if anyone has come across any vendors that stocks these, some pointers would be much appreciated.
2001 996.2 C2
 Filesize:  113.64 KB
 Viewed:  480 Time(s)
PostPosted: Thu Sep 05, 2019 12:52 am    Post subject: Reply with quote
Look like original metal centre caps to me Thumb
Gazc2
PostPosted: Thu Sep 05, 2019 7:33 am    Post subject: Reply with quote
I agree look as though they have been polished up, you need to measure the cap hole on your wheels to see if the older caps fit, I also think I have some of these stashed in the garage I will have a look tomorrow when I get back.
https://www.ebay.co.uk/itm/Porsche-911-Fuch-Fuchs-Black-Metal-Centre-Caps-Genuine-91136103228-Full-Set/254341524797?epid=1716411492&hash=item3b37efad3d:g:RNQAAOSwFDBdY-M6
2007 997 Turbo & 924s in progress
1990 964 C2
1989 3.2 targa
1987 3.2 Cab
1986 3.3 Turbo
sp1ke
PostPosted: Thu Sep 05, 2019 12:14 pm    Post subject: Reply with quote
thanks for the input. Sorry I should have mentioned the size:
Internal diameter is 72mm
External diameter of the central ring between the petals is 81mm
So 71mm caps should fit with a bit of fettling.
@Gazc2 if you find your old ones, & they are 71mm ish then please do PM me.
If anyone else has come across these for sale when browsing for parts online, or has some for sale, then I'd love to hear from you.
2001 996.2 C2
sp1ke
PostPosted: Sun Sep 08, 2019 7:01 pm    Post subject: Reply with quote
doh!
I eventually figured out Design911 have a variety of similar 71mm caps, but they weren't showing up for me as I'd set the default car settings for a 996. If you select an older model, then you should see the full range:
https://www.design911.co.uk/fu/pt179_433_-cma81-cmo104-ct359/Porsche/911-1965-1989/911-1974-83/Centre-Caps-for-Fuchs-wheels/
2001 996.2 C2
