991 : 2011- 18
997 : 2004- 80
996 : 1997-2005 33
Boxster : 1997- 25
SGH
2010 Porsche 997 Carrera 4S
PostPosted: Wed Sep 04, 2019 3:56 pm    Post subject: Wheel Spacers & Bolts Question Reply with quote
At the moment I have 5mm spacers front and rear with Genuine Parts extended wheel bolts.
My question is, if I fit 10mm spacers on the rear will I be ok with the same Genuine Parts extended wheel bolts I already have?
Porsche 997.2 Carrera 4S - Carrara White / Cocoa
Defender 300Tdi 110 HCP - Keswick Green
Connect L2 Double Cab - Moondust Silver
VW California Ocean 150PS DSG - Reflex Silver
FZP
Estoril
PostPosted: Wed Sep 04, 2019 4:55 pm    Post subject: Reply with quote
Hahaha
I've just seen your post on the 997 page on Facebook, but for the love of Jeebus, you must post that picture up for all to see. That is amazing. It deserves it's own thread!
PostPosted: Wed Sep 04, 2019 5:53 pm    Post subject: Reply with quote
If everything is porsche then with wheel spacers you have a red collar on the bolts .. standard is shorter and does not have this .
If you already have spacers then you should have this type fitted ... 5 or 10 mm and it's the same bolt .
Remove one and check .
SGH
PostPosted: Wed Sep 04, 2019 6:01 pm    Post subject: Reply with quote
Ian
No red shank I got these from OPC Tonbridge part number PWHT.004.676.A
 Filesize:  129.15 KB
 Viewed:  534 Time(s)
PostPosted: Wed Sep 04, 2019 6:11 pm    Post subject: Reply with quote
I've only ever seen x2 types of wheel bolts i'm afraid .. one for spacers and one without .. if 10 mm on the rear is a Porsche specified spacer and i think it is then its the red collar ..i checked here but it lists only 5mm front and rear ..
That bolt has nothing to tell it apart from a spacer type .
https://www.deroure.com/diagrams.asp?TBL=2827&MAK=3&MDL=26&SMA=0&SMO=0&ST=&SC=0
i don't know the measurements for both types im afraid .
Simple answer though .. ask porsche parts department .. Tonbridge are always very helpful .
EDIT
https://www.porscheshop.co.uk/porsche-wheels-accessories/wheel-spacers-for-porsche/locking-wheel-bolts-cayenne-oe.html
Billy Bumpsteer
PostPosted: Wed Sep 04, 2019 6:42 pm    Post subject: Reply with quote
The ones you have are 7mm longer than standard so would be ok just for 10mm shims
The black versions dont have the coloured collars on them
Demort, please dont post listing from that place! They are hated are rightly so!
PostPosted: Wed Sep 04, 2019 6:44 pm    Post subject: Reply with quote
Embarassed
i was just after the pictures .. honest .
Goes off to sulk in a corner ...
Billy Bumpsteer
PostPosted: Wed Sep 04, 2019 6:54 pm    Post subject: Reply with quote
Arhhh, Sad where the hug emoji? Friends
SGH
PostPosted: Wed Sep 04, 2019 8:23 pm    Post subject: Reply with quote
Thank you thumbsup
PostPosted: Thu Sep 05, 2019 6:56 pm    Post subject: Reply with quote
Floor
I'm good ..
shows i don't know everything ..
Shows i try even when i don't Smile
Shows other people will answer with the correct info Thumb
