991 : 2011- 18
997 : 2004- 80
996 : 1997-2005 33
Boxster : 1997- 25
Ratattak
PostPosted: Tue Sep 03, 2019 5:39 pm    Post subject: Help please - Low power mode warning light Reply with quote
After a normal drive into town today (11 miles) the "Low Power Mode' warning came on. I parked up and checked that all dials were normal and then switched off. After about 10 minutes I started the car up and all was well, again with all dials and warning lights normal.
The warning lit up again after 300 yards so I parked up again and awaited recovery. I noticed that the fans were not coming on as they usually do after a (less than spirited) drive.
My initial thoughts are that the fans have stopped working for some reason rather than anything catastrophic. (hopefully a fuse or sensor ?)
My car is a 2009 997.2 Carrera 2S.
The car is full of oil and was serviced about 1000 miles ago.
Any comment/advice would be gratefully received before I talk to my trusted indy tomorrow.
PostPosted: Tue Sep 03, 2019 6:34 pm    Post subject: Reply with quote
My guess would be the high pressure fuel pump is messing around and will need replacing.
I'm afraid without a fault code read out there's little i can say .. the engine has gone into protect mode due to a fault which has .. got the car worried shall we say .. hence the message .
Pump is all that springs to mind .
Ratattak
PostPosted: Tue Sep 03, 2019 7:31 pm    Post subject: Reply with quote
@deMort - Many thanks for your swift response - sounds expensive though !
PostPosted: Tue Sep 03, 2019 7:51 pm    Post subject: Reply with quote
Bad but not too bad shall we say .. if it is that .. i'm making a guess based on past experience and so may well be totally wrong .
Ratattak
PostPosted: Fri Sep 13, 2019 7:44 pm    Post subject: Reply with quote
Spot on - fault has not reappeared since the garage sorted it out so they're keeping the car to check it out further - I'll collect Tuesday
Thanks again Smile
