997 : 2004- 60
996 : 1997-2005 29
Boxster : 1997- 26
Paul Farrar
PostPosted: Mon Sep 02, 2019 9:20 pm    Post subject: Exhaust Trims on PSE Reply with quote
For the 2nd time, one of the painted 'cowls' on my PSE fell off...! I lost the first a couple of years ago out on the road somewhere, so that was that. Today however, it was on the track at Thruxton, so I was eventually able to recover it, between sessions, slightly chipped, but otherwise re-usable.
They had the correct 'anti-vibration' washers in place, but still one of them let go! I then removed the remaining one as a precaution.
I am wondering whether this is a regular occurence, as I can't recall this topic being raised previously? Maybe Loctite as well next time...?
currently:
997 Gen 2 Carrera S - 2010 (59) - GT Silver - Manual
previously:
993 Carrera S - 1996 (P) - Zenith Blue - Manual
993 Carrera 2 - 1993 (L) - Polar Silver - Manual
944 Turbo - 1990 (G) - Panther Black - Manual
Hertsdriver
2004 Porsche 997 Carrera 2
PostPosted: Tue Sep 03, 2019 8:17 am    Post subject: Reply with quote
do you mean the tailpipes?
Paul Farrar
PostPosted: Tue Sep 03, 2019 5:34 pm    Post subject: Reply with quote
Not the full tailpipe, just the 'cosmetic' painted trim/shroud that surrounds the tailpipes on the PSE.
currently:
previously:
badbadtz
PostPosted: Tue Sep 03, 2019 11:31 pm    Post subject: Reply with quote
Surprised to hear they fell off as I couldn't remove mine even though I tried hard. The outer trim held on by a single hex bolt right?
Paul Farrar
PostPosted: Wed Sep 04, 2019 6:58 am    Post subject: Reply with quote
That's right. A single M8 x 20 bolt with a so-called anti vibration washer. I've had mine off a couple of times over the years for cleaning and/or repainting the ends of the tailpipes themselves. Maybe therein lies the problem as they haven't been allowed to 'weld' themselves together......! I shall have a close look at the fixing method and see if there's any way I can make it more robust. Otherwise I'll definitely use some Loctite next time around.
currently:
previously:
