991 : 2011- 18
997 : 2004- 80
996 : 1997-2005 33
Boxster : 1997- 25
Moko
PostPosted: Mon Sep 02, 2019 7:23 pm    Post subject: Anyone Using Yatour Bluetooth Kit? Reply with quote
Just wondering if anyone can answer some questions on this kit available on Amazon https://www.amazon.co.uk/dp/B07DC6GK9S/?coliid=I36QVSOAXJNQPL&colid=VNGX9P76MZ4Z&psc=1&ref_=lv_ov_lig_dp_it
My 996 has the basic CD22 Radio/CD player with a separate CD changer from the looks of it just has standard RCA plugs not the optical fibre but it does have what looks like a separate Amp next to the changer.
In operation can you use something like Waze and the voice come through the cars speakers and then will the Navigation go silent if you answer a phone call?
I’ve never used a system like this and am just trying to work out it’s limitations
Porsche Seal Grey 996 Carrera 02 Tiptronic
wasz
1999 Porsche 996 Carrera 2
PostPosted: Tue Sep 03, 2019 10:14 am    Post subject: Reply with quote
Its just a bluetooth adapter that pretends to be a cd changer
You plug it in place of the CD changer (you lose the cd changer).
Your phone is the source of everything. You can play music on your phone (you will likely need to instigate this when you start the car) then you can change tracks on the headunit. It will be awkward to search for a track - you will need to use the phone screen for that.
You can use waze as nav - you will have to use the phone screen to set this up.
You can do both at the same time - set music playing, set nav going. The nav will override the music.
If you get a phone call you can press a button on the Becker to answer / hangup and it will go back to your nav/music afterwards.
What you can't do is listen to the FM radio and expect it to switch. The headunit will have no idea a call is coming in or you need navigating. The Becker will have to be set to "CD changer" and you have to play any music via your phone.
I have a similar setup (£2 aux wire and £10 bluetooth adapter) but it doesn't pretend to be a cd changer so I have to use the buttons on the adapter or the phone screen to change tracks or recieve calls.
I use BBC sounds app or tune in to get radio via the phone data connection when I want radio and nav or expect a call. In practice if you can see the phone screen you know a call is coming in, so can manually switch the headunit (in my case to aux) to talk.
baldguy
PostPosted: Tue Sep 03, 2019 10:28 am    Post subject: Reply with quote
I have one of these but only use it for Ipod conectivity on a CDR and works well.... sorry but cant comment on the BT part of it...
958 Cayenne Turbo - Amethyst
996 Carrera 4 - Lapis
Moko
PostPosted: Tue Sep 03, 2019 4:57 pm    Post subject: Reply with quote
Thanks as always that’s just the information I needed.
As the sound is always going to be pretty rubbish in my 996 unless I change the speakers get a sub etc. there’s not a lot of point in me getting a double DIN when I would only use it connected to CarPlay so I might as well save what basically would just be a bigger screen in the car.
Doesn’t seem to much of a restriction to keeping the original Becker head unit on Aux/CD changer.
