991 : 2011- 18
997 : 2004- 80
996 : 1997-2005 33
Boxster : 1997- 25
barefoot
PostPosted: Sat Aug 31, 2019 8:29 am    Post subject: Xtrons head unit Reply with quote
I fitted a double din head unit a bit ago and it has two USB leads coming out of the back of it and I ran them through to the glove box obviously not an ideal place. I then saw some connector leads on eBay and fitted them between the heated seat switches I think they look fine and they are a lot easier to use. I thought I would post some pics in case anyone else has a similar head unit.
PostPosted: Sat Aug 31, 2019 8:58 am    Post subject: Reply with quote
I did something similar: http://911uk.com/viewtopic.php?t=126102
barefoot
PostPosted: Sat Aug 31, 2019 1:53 pm    Post subject: Reply with quote
Wow great job in fairness... Mine looks a lot less work just unclip the heated seat trim and dremmel out the 2 holes that the USB adaptors clip into. Then push trim back in they are a bit more accessible as well. But if you want them out of the way and not seen yours is spot on.
PostPosted: Sat Aug 31, 2019 2:09 pm    Post subject: Reply with quote
Have you got a fitting kit for your head unit?
barefoot
PostPosted: Sun Sep 01, 2019 7:21 am    Post subject: Reply with quote
I got it from a guy in the states I spend a lot of time over there. Really well made the plate/trim around the head unit is a gloss black plastic that looks great.
PostPosted: Sun Sep 01, 2019 8:27 am    Post subject: Reply with quote
thumbsup
