Suspension refresh
Poker2009
9 Sep 2009
1,135
Hi
I am planning on a suspension refresh with Ohlins.
I am struggling with all the different part numbers, and the differing names for the same items.
Are "forks" the same thing as what people call "diagonals"?
Thankyou for any help!
Hi Vin
As per my PM, here is the list of parts I bought when I had my suspension sorted at CG, excluding the Ohlins which I bought from D911.
Please note that my car is model year 2006, there may be some differences between model years so worth double checking everything. The Meyle website is worth a look to check part numbers, also the Elephant Racing suspension navigator is worth a look to get your head around how the suspension works.
https://www.elephantracing.com/996-997-suspension-navigator/
Here are the links to the eBay items, ps. never trust what the eBay seller or part checker says, they are quite often wrong. Where possible check agains the OEM part number.
Front lower control arms
https://www.ebay.co.uk/itm/PORSCHE-...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
Rear lower control arms
https://www.ebay.co.uk/itm/Porsche-...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
Front diagonals
https://www.ebay.co.uk/itm/PORSCHE-...M-997407150-/173961401191?hash=item2880e85367
Front top mounts
https://www.ebay.co.uk/itm/2x-SACHS...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
Top mount bearing
https://www.ebay.co.uk/itm/Top-Susp...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
Inner track rods - WARNING - think I got this part number wrong!! :?: https://www.ebay.co.uk/itm/PORSCHE-...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
Outer track rods ends
Front drop links
And a pic of all the bits!
Poker2009 said:
Hi
Tuning forks are diagonal arms .. they are bolted to the center bush in each coffin arm , they get called different names is all .
Hi Rob
Thankyou very much for this, it is a lifesaver - I was pulling my hair out trying to to work out what is what!
I am finding a few bits on autodoc, as well as eBay - which will save quite a bit of money.
deMort said:
Poker2009 said:
Hi
Thankyou - I managed to work it out earlier today - by deduction! People use so many different names for the same thing. Gathering part numbers and comparing prices, is not as straight forward as I thought it would be.
Poker2009 said:
deMort said:
Poker2009 said:
Hi
Took me forever too and it is confusing with all the differing part names! Still manage to order the wrong track rod ends and front lower control arms! Definitely worth checking and double checking part numbers!
let me just say at work i can look at different systems for parts and instructions and the same part is called different names ..
It's the german to english translation that's the problem .. there is no one guy doing this but many and there is often no direct translation of what they call an item to what we would call it so they do their best .
We also use slang a lot more ( not sure the Germans do this ) .. it looks like a tuning fork to be honest !
It goes at a diagonal angle to the coffin arm :)
In geometry, a diagonal is a line segment joining two vertices of a polygon or polyhedron, when those vertices are not on the same edge. Informally, any sloping line is called diagonal.
That's a quote btw as i'm not that intelligent !
I almost there gathering part numbers, and where to source from.
Does the rear require 4 dogbones?
Porsche p/n: 997 331 047 01
Meyle p/n: 416 050 0008
AND
Is the "Toe Arm" the same as "REAR Drop links"? Left and Right required?
Timely post as I am considering having similar work done soon.
A few questions that might be relevant:
- How about anti-roll bar bushes, should these be changed "while there" too?
- Porsche OEM suspension arms are TRW. Anyone know where these can be purchased? Are Meyle suitable? (I read somewhere on a forum that there is more variance in their bushings resistance, this was based on actual research, not just speculation)
TRW I have seen only on autodoc.co.uk, it is OE quality, but is about twice the price of Meyle. I have been told the Meyle parts are just as good, and others have used with no issues. I have read about size issues a long time ago, but nothing recently - perhaps the issues are resolved, but I am not 100% certain.
Anti-roll bar bushes, I do not intend to replace.
I also found this thread useful. Thanks.
Can anyone advise on the difference between the attached picture? They're both rear track control arms and there's a £30 difference but not sure which ones I'd need for 997.1 c2s.
The ones at £140
p/n 416 050 0009
are what I bought in for my car (which is a 997.1 C2S)
This website looks like a copy of autodoc.co.uk!
FRONT SUSPENSION PARTS:
Sachs front top mount 2 £38.04 Autodoc 802553 997 343 018 01
H-Tech, anti-friction bearing 2 £46.46 carparts4less.co.uk 414 641 0002 996 343 515 05
Meyle track control arm (front) 2 £198.45 eBay: johnyboy-1 416 050 0005 997 341 053 04
Meyle Diagonals aka Forks (front) 2 £132.20 Autodoc 416 050 0006 997 341 143 00
Meyle Drop links (LEFT) 1 £18.91 Autodoc 416 060 0012/HD 997 343 069 04
Meyle Drop links (RIGHT) 1 £18.91 Autodoc 416 060 0013/HD 997 343 070 04
TRW inner rod end (front) 2 £46.38 Autodoc JAR1041 997 347 322 01
TRW outer rod end (front) 2 £45.46 Autodoc JTE760 996 347 131 04
Porsche front anti-roll bar bushes 2 £28.95 eBay: 9-apart-ltd 996 343 792 17
REAR SUSPENSION PARTS:
Meyle track control arm (rear) 2 £255.00 eBay: johnyboy-1 416 050 0009 997 331 053 03
Meyle Diagonals aka Forks (rear) 2 £128.04 Autodoc 416 050 0004 997 331 043 01
Meyle Rear Drop links (LEFT) 1 £17.70 Autodoc 416 060 0015 997 333 069 06
Meyle Rear Drop links (RIGHT) 1 £16.67 Autodoc 416 060 0016 997 333 070 06
Meyle dogbone (rear) 4 £203.24 eBay: dusty789blue 416 050 0008 997 331 047 01
Meyle toe arm (rear) 2 £115.90 eBay: johnyboy-1 416 050 0007 997 331 045 04
OEM rear top mount 2 £264.70 Porsche 997 333 061 01
Meyle Engine mounts (pair) 1 £276.22 Autodoc 414 375 0003 997 375 049 06
124,595
1,441,948
49,027
Monkey
