991 : 2011- 18
997 : 2004- 80
996 : 1997-2005 33
Boxster : 1997- 25
Moko
PostPosted: Tue Aug 27, 2019 9:46 pm    Post subject: Air Induction Box Will 3.4 fit a 3.6 Reply with quote
Hi my Carrera 2 996 02 came with a K&N induction kit already fitted and I was thinking about returning it to stock and wondered if the 3.4 induction box would be ok to use on my 3.6?
Hope I’ve used the correct terminology for the big plastic air filter box Very Happy
Porsche Seal Grey 996 Carrera 02 Tiptronic
yo_clarkie
PostPosted: Wed Aug 28, 2019 2:57 am    Post subject: Reply with quote
If you have to buy one, why not put in a 997 one, much prettier Smile
https://www.ebay.com/itm/Porsche-911-997-Luftfilterkasten-Luftfilter-gehause-Air-box-Intake-99711002300/153583443204?hash=item23c2495d04:g:pMoAAOSwvdxdPapG
2003 996 C4S in Silver, Manual, PSE, new in UK, now in New Zealand
Mods so far: K&N induction, Kenwood Navigation and AMP, LN Engineering IMS, fully replaced suspension with new factory parts
Moko
PostPosted: Wed Aug 28, 2019 6:46 am    Post subject: Reply with quote
As pretty as that one is.. it’s ten times more expensive than the one I’ve seen Smile
NLW73
PostPosted: Thu Aug 29, 2019 10:26 am    Post subject: Reply with quote
same boxes. cheap as chips and loads out there.
block off the hole and take out the helmholz resonator. easy on 996 as screwed.
there is a nice BMC panel filter and block off and cold air intake hose for sale in the parts area here.
much better sound and breathing and easy to fit.
997 C2s Schwarz
Moko
PostPosted: Thu Aug 29, 2019 4:28 pm    Post subject: Reply with quote
Thanks for the reply....does mine being a Tiptronic make any difference or are they the same for all models?
NLW73
PostPosted: Thu Aug 29, 2019 5:37 pm    Post subject: Reply with quote
Not as far as I am aware.
The Tiptronic has a different set up around around the throttle body and Inlet manifold to help with gear box breathing and oil returns.
You might want to check with an Indy first
997 C2s Schwarz
Moko
PostPosted: Thu Aug 29, 2019 7:12 pm    Post subject: Reply with quote
Your recommendations are too good the filter etc sold almost immediately after your post Smile
Moko
PostPosted: Sun Sep 22, 2019 9:23 pm    Post subject: Reply with quote
In the end I managed to source a perfect condition airbox off EBay for the huge sum of £17 and the seller even threw in a brand new boxed air filter for it Laughing
I just hope running my 996 keeps on being this cheap thumbsup
