997 : 2004- 63
Cayman : 2005- 22
Macan : 2014- 7
Stephenjk
PostPosted: Mon Aug 26, 2019 11:19 am    Post subject: Air box crack Reply with quote
I'm dont know if this is a common failure but i found this when changing my air filter. Looks like a PO or garage had tried to remove the front half without removing the clips, cracked the rear housing and then botched a repair. The rear of the filter was held on with cable ties. No one incl last two garages servicing the car, mentioned the problem which i thought was a bit odd.
I've replaced it now with a second hand part, if anyone fancies having a go to repair this they can have it for the cost of postage!
I also now have a spare front of airbox if anyone is interested listed here
http://rover.ebay.com/rover/1/710-53481-19255-0/1?icep_ff3=2&pub=5575378759&campid=5338273189&customid=&icep_item=113865876791&ipn=psmain&icep_vectorid=229508&kwid=902099&mtid=824&kw=lg&toolid=11111
 Filesize:  357.72 KB
 Viewed:  736 Time(s)
 Filesize:  374.67 KB
 Viewed:  736 Time(s)
