991 : 2011- 18
997 : 2004- 80
996 : 1997-2005 33
Boxster : 1997- 25
Maxthedane
PostPosted: Sat Aug 24, 2019 10:59 am    Post subject: Question about key Reply with quote
Hi
I've had a quick search but can't find an answer to what might be a relatively simple question.
I've been locking my car with a press of the key fob. I think I double pressed it quickly this morning and the horn honked - is this a 'deadlock'. Is double click different to single click as far as locking the car is concerned?
thanks
Paul
PostPosted: Sat Aug 24, 2019 12:01 pm    Post subject: Reply with quote
The honk you heard is the car telling you that something is open. Obvious things would be a door, frunk or the engine cover. Less obvious things are the glovebox, centre stowage and iirc the door storage covers.
If you double press the locking/unlocking button you'll be locking the car and then unlocking it again.
Maxthedane
PostPosted: Sat Aug 24, 2019 5:02 pm    Post subject: Reply with quote
Thanks for the info. I'll keep an ear out for the honk & double check if it happens again.
Paul
PostPosted: Sat Aug 24, 2019 7:35 pm    Post subject: Reply with quote
If you leave a dog in the car and lock it then it will trigger the alarm due to the interior monitoring sensor .. it senses movement .
you double press the fob button to deactivate this part of the alarm system so that any movement in the car will not trigger the alarm .
Horns beeps and the indicators should flash to tell you you have activated this type of alarm lock .
Its something i use often when trying to find a battery discharge fault and i have the door open so i have access to the fuses to test for a discharge .
Im guessing it will be in the handbook .
Maxthedane
PostPosted: Sat Aug 24, 2019 8:28 pm    Post subject: Reply with quote
thanks Iain
PostPosted: Sat Aug 24, 2019 9:53 pm    Post subject: Reply with quote
Seems like I was wrong with
It's a long while since I used a 996 key. Sorry. Embarassed
PostPosted: Sun Aug 25, 2019 4:23 pm    Post subject: Reply with quote
P 21 of the owner's manual , locking conditions.. image below ..
I don't have a PDF of a 997 owners manual so cant check but i think its going to be the same .. give it a try Smile
T8 was perfectly correct but on a one press of the button .
 Filesize:  372.47 KB
 Viewed:  458 Time(s)
