Boxster : 1997- 25
davidjf7
PostPosted: Thu Aug 22, 2019 12:07 pm    Post subject: Front wheel arches Reply with quote
Hi all,
My 997 is suffering from surface rust and the paint peeling away where stones have hit the front arches just above the plastic guards.
Want to get this sorted before winter.
Is this a DIY job (thinking some kind of anti-corrosion paint + spray paint + lacquer and then maybe a protective covering) or would it be better entrusted to a pro?
Thanks Thumb
KA14LON
PostPosted: Thu Aug 22, 2019 1:07 pm    Post subject: Reply with quote
I have the same issues. Thinking of going down the DIY route.
fine grit sanding paper and some hammerite kurust to treat the rust and then some clear protective film.
Windy101
PostPosted: Thu Aug 22, 2019 1:48 pm    Post subject: Re: Front wheel arches Reply with quote
davidjf7 wrote:
Hi all,
Thanks Thumb
I have been pondering whether this is DIY job as well. I have 3 911's and they are all suffering from this to varying degrees. Will be interested to see what the consensus is.
KA14LON
PostPosted: Wed Aug 28, 2019 2:44 pm    Post subject: Reply with quote
I phoned Porsche East London and they said this is not covered under the 12 anti-corrosion warranty as this damage is due to stone chips and due to characteristics of the car!
boardingnath997
PostPosted: Wed Aug 28, 2019 3:26 pm    Post subject: Reply with quote
I got the same response for a similar issue on my rear wheel arches from Brooklands
2009, 997.2 Carrera S PDK
montygraphics
PostPosted: Wed Aug 28, 2019 8:43 pm    Post subject: Reply with quote
If yours is a dark colour use dinatrol dark wax to stop and protect edges from corrosion.
Self healing and easily topped up occasionally. Works a treat.
KA14LON
PostPosted: Fri Aug 30, 2019 10:19 am    Post subject: Reply with quote
Has anyone tried putting mud flaps on the front arches for protection ?
I think I will buy some universal front mud flaps and give them a try.
Cannop
PostPosted: Fri Aug 30, 2019 10:57 am    Post subject: Reply with quote
I had all of my arches Armourfended when I had them stripped treated and painted, it's a type of tough PPF designed for wheelarches.
You can just about make it out in this photograph.
Full fat Hartech'd C2S Manual
jonno_
2005 Porsche 997 Carrera 2S
PostPosted: Fri Aug 30, 2019 4:47 pm    Post subject: Reply with quote
Think that armourfend is same / similar to 3m 'helicopter tape'.
Supposedly used on leaving edge of rotor blades. Though I use it on my mountain bike.
It's very tough stuff.
stichill99
PostPosted: Fri Aug 30, 2019 4:55 pm    Post subject: wheel arches Reply with quote
Cannop, did you just get the arches painted and then blending laquer over the join. I would like to get mine done but the first bodyshop i approached said he would need to paint the complete side of the car Surprised
Cannop
PostPosted: Sat Aug 31, 2019 8:24 am    Post subject: Reply with quote
I started out with just wanting the wheel arch lips done and on the front that's how they were treated, stripped back, rust converted, primed, painted, lacquered and armourfended. Whilst the rears arch lips were being done I had some paint defects on the rear 3/4 panels and drivers door and stone chipping on the sills and rear bumper sorted out at the same time.
davidjf7
PostPosted: Mon Sep 02, 2019 3:05 pm    Post subject: Reply with quote
Sounds like a good solution Thumb
Is it this stuff?
[/img]
 Filesize:  131.71 KB
 Viewed:  1113 Time(s)
davidjf7
PostPosted: Mon Sep 02, 2019 3:15 pm    Post subject: Reply with quote
Meant to say, my car's basalt and this looks like it's brown?
craig15
PostPosted: Mon Sep 02, 2019 4:58 pm    Post subject: Reply with quote
You get 4941 which is thicker and dries harder which is meant to go over the top of the thinner brown 3125. The 4941 is black.
Craig
montygraphics
PostPosted: Mon Sep 02, 2019 11:17 pm    Post subject: Reply with quote
Yes I use 3125. Very nearly black but the black coating suggested by Craig may be even better. Dinitrol products really work well.
davidjf7
PostPosted: Tue Sep 03, 2019 8:55 am    Post subject: Reply with quote
Thanks both, super helpful thumbsup
Also found this - any thoughts whether it would be better? Looks like the main difference is that it's over-paintable in case the colour match isn't great
 Filesize:  84.77 KB
 Viewed:  915 Time(s)
montygraphics
PostPosted: Tue Sep 03, 2019 11:18 pm    Post subject: Reply with quote
I think 447 requires good preparation to remove all rust first more like the finish sprayed inside wheel arches or on seams during the build process. As it’s possible to paint over it you will be able to colour match. It won’t self heal as well as the wax based products though.
davidjf7
PostPosted: Thu Sep 05, 2019 10:53 am    Post subject: Reply with quote
Thanks for all the input Thumb
Spoke to a very helpful lady at Dinitrol. Her advice:
Steam clean area, let it dry, mask off area, apply RC900 rust converter, allow to cure overnight, then apply a fine mist of 3125, then 4941.
So this is what I'm going to do in the next couple of weeks
montygraphics
PostPosted: Thu Sep 05, 2019 9:42 pm    Post subject: Reply with quote
Good. Let us know how you get on.
