997 : 2004- 56
Carrera SC : 1977-1983 3
Boxster : 1997- 24
Cayman : 2005- 22
Cayenne : 2003- 7
MarkGolf
PostPosted: Thu Aug 22, 2019 8:57 am    Post subject: Distributor belt DIY? Reply with quote
Hi Guys,
Had the 964 out last night and after a 30 min perfectly fine drive, I put my foot down and just had a mass of hesitation, pinking, rasp and a gradual pick up in speed until it burst into life and off it went.. Backed off, tried again and it wasn't as bad but still had a miss, revving the car in neutral, no problem, revs fine. Got home and I could hear a miss but it seemed to clear itself, so it is very much intermittent.
The plugs are new, they proper spec Beru ones. The leads are not too old. I don't drive the car much, had it out for a meet last time and it performed faultlessly.
The caps and the rotors appeared clean the last time they were off when I did my valve clearances(less than 200 miles ago) but they did have some mild wear on some of the tips, so I am going to change those as part of a refresh to cure this prob. Whilst I am doing that, it makes sense to change the belt in the dual disti setup as I have no record of that being changed.
So my question, has anyone gone about swapping the belt themselves? Is it a worthwhile DIY or best to ship it off to a specialist for a full service? (If anyone does that).
Mark
Current fleet
1991 964 Carrera
2005 997 Carrera S
2008 957 Cayenne GTS
2003 Boxster 2.7
1991 Mercedes 500SL
1979 Mercedes 280e
1995 VW Golf VR6 3.0
Windy101
PostPosted: Thu Aug 22, 2019 9:44 am    Post subject: Reply with quote
Have a look here
http://911uk.com/viewtopic.php?t=130832&highlight=
A member here Diddi seems to specialise in this and a number of people on here have used him for both parts and full refurb service.
Windy101
PostPosted: Thu Aug 22, 2019 9:46 am    Post subject: Reply with quote
Ebay Link seems to be dead but he is your man. There are a number of threads on here discussing this is you search.
MarkGolf
PostPosted: Thu Aug 22, 2019 10:48 am    Post subject: Reply with quote
Perfect, thanks for that, that's got me on the right track!
I am going to pull mine off and see what is needed, then contact diddi to source the bearing kit, should change all of them while there.
Parts list isn't huge and other than a link on ebay.de, no idea where to get the bearings.
Belt CONTI CT-1032
3 x INA 7201 (32x10x12,45mm)
1 x INA NX12
Pin
Someone on ebay.de selling the kit for 180 euro
https://www.ebay.de/itm/7201-Lager-3x-Zahnriemen-CT-1032-REV-SET-f-Porsche-964-993-Zundverteiler-7/163759056211?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20131017132637%26meid%3D9032004bcc5141a69de341ecf72bcf2e%26pid%3D100033%26rk%3D3%26rkt%3D8%26sd%3D254246374580%26itm%3D163759056211%26pmt%3D0%26noa%3D1%26pg%3D2045573&_trksid=p2045573.c100033.m2042
Thanks!
Current fleet
1991 964 Carrera
2005 997 Carrera S
2003 Boxster 2.7
1991 Mercedes 500SL
1979 Mercedes 280e
Diddi
PostPosted: Thu Aug 22, 2019 5:34 pm    Post subject: Reply with quote
Hi all,
what you want ? Ask via PM !
Grüsse, Diddi
MarkGolf
PostPosted: Wed Sep 11, 2019 11:46 pm    Post subject: Reply with quote
Just pulled mine apart, belt had been done before and only just starting to show some age.
2 of the 7201 bearings need replacing as I can wobble the centre slightly, so I need to locate some of those.
How are they best removed?
Current fleet
1991 964 Carrera
2005 997 Carrera S
2003 Boxster 2.7
1991 Mercedes 500SL
1979 Mercedes 280e
MarkGolf
PostPosted: Wed Sep 11, 2019 11:56 pm    Post subject: Reply with quote
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F322294805713
These the ones?
Current fleet
1991 964 Carrera
2005 997 Carrera S
2003 Boxster 2.7
1991 Mercedes 500SL
1979 Mercedes 280e
Diddi
PostPosted: Thu Sep 12, 2019 1:22 pm    Post subject: Reply with quote
......important, the bearings are 32 x 10 x 12,45mm
Grüsse, Diddi
Diddi
PostPosted: Tue Oct 08, 2019 5:44 pm    Post subject: Reply with quote
......complete revision-SET for your Dizzy
info at d964@gmx.de
Grüsse, Diddi
 Filesize:  1.51 MB
 Viewed:  1512 Time(s)
