997 : 2004- 66
996 : 1997-2005 34
964 : 1989-1993 1
Cayman : 2005- 20
Cayenne : 2003- 7
Macan : 2014- 6
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Wed Aug 21, 2019 4:11 pm    Post subject: Can you tell what it is yet? Reply with quote
Starting to look like it is nearly ready to go in the car....
PostPosted: Wed Aug 21, 2019 4:15 pm    Post subject: Reply with quote
Its hard to tell from so few pictures Grin
cheshire911
Estoril
PostPosted: Wed Aug 21, 2019 4:20 pm    Post subject: Reply with quote
Yes, agreed. Need a few more pictures for a diagnosis.......
996 2002 X50 Turbo Manual
FZP
Estoril
PostPosted: Wed Aug 21, 2019 4:31 pm    Post subject: Reply with quote
It appears to have a couple of Babyliss hair dryers. Is this the new air cooled? Floor Floor Floor
MisterCorn
PostPosted: Wed Aug 21, 2019 5:07 pm    Post subject: Reply with quote
Gearbox parts are mostly in. Hopefully there will be some photos of that in the near fiture. 2 piece GT2 RS mainshaft, full set of Guards straight cut gears with LSD and billet cover plate.
PostPosted: Wed Aug 21, 2019 5:11 pm    Post subject: Reply with quote
M96.70
Porschekit
PostPosted: Wed Aug 21, 2019 5:15 pm    Post subject: Reply with quote
Is that a waffle sprocket connected to the baffle head?? Confused
997.1 C4S Meteor Grey Metalic
MisterCorn
PostPosted: Wed Aug 21, 2019 5:23 pm    Post subject: Reply with quote
Alex wrote:
M96.70
Yes, with 997 inlet manifolds. I'll post a full spec when it is done.
coullstar
PostPosted: Wed Aug 21, 2019 5:49 pm    Post subject: Reply with quote
Turbo's M96.....wow. what the spec?
PostPosted: Wed Aug 21, 2019 7:20 pm    Post subject: Reply with quote
For me .. the best picture is below .. the water take off .
That's just a work of art period !
I dream of being able to ally weld like that .. never going to happen though sigh .
 Filesize:  117.06 KB
 Viewed:  2147 Time(s)
MisterCorn
PostPosted: Wed Aug 21, 2019 7:50 pm    Post subject: Reply with quote
I'm away on holiday at the momeng and don't have access to all the details, but this started its journey with me as an £1800 eBay purchase of a complete 996 turbo engine with a dropped valve, which meant a damaged head and a damaged piston. I had thought about having a go at rebuilding it myself for shits and giggles, but sense got the better of me and it was sent to Matt at Fearnsport where it was stripped down and put back together. I'll update the spec when I can confirm details.
New liners and pistons, 3.8l
Ported heads, standard size valves
GT3 exhaust camshafts
ARP head studs and big end bolts
Carrillo rods
997 inlet with 1100cc injectors
Meth injection
IPD plenum with 84mm?? throttle body
Fenderwell intakes
Custom y pipe
Custom exhaust
Custom intercoolers
Big turbos, water cooled Smile
Syvecs ECU
Full pressure and temperature monitoring
Pre and post turbo and intercooler
Coolant pressure and temperature
6 exhaust temperatures
Converted to 2wd
Full Guards gearbox rebuild with LSD and straight cut gears
custom gearing approximately 10% longer
2 piece mainshaft
GT2 clutch conversion with adjustable stop
Triple plate carbon clutch with very light flywheel
Suffice to say, it is turning in to a very expensive cheap engine.
Rosselder83
PostPosted: Wed Aug 21, 2019 10:09 pm    Post subject: Reply with quote
The AN fittings you have added to the lines in and out of the turbo sumps, where did you get them from?
It looks like I’m going to have to chop my lines and this looks like a neat way to save an otherwise perfectly good line.
Plus AN fittings are sexy
MisterCorn
PostPosted: Thu Aug 22, 2019 6:28 am    Post subject: Reply with quote
Matt at Fearnsport sorted all of those. No idea, sorry.
Rosselder83
PostPosted: Thu Aug 22, 2019 8:05 am    Post subject: Reply with quote
No problem mate, appreciate the heads up
MisterCorn
PostPosted: Sat Nov 23, 2019 2:47 pm    Post subject: Reply with quote
A couple of shots of gearbox parts.
The input shaft is in 2 pieces, the part which goes in to the clutch is a springy steel to reduce the shock loading, the part where the gear stack fits is gear steel for strength. Gear tooth count is reduced from what Porsche run for wider gear tooth base, making the gears stronger. Shame to hide it away in the gearbox, great engineering.
NedHan79
PostPosted: Sun Nov 24, 2019 8:47 am    Post subject: Reply with quote
So long as it works is all that matters. That looks like it’ll make close to 500 ponies Floor
Should be a lot of fun. It sorta pokes fun at all who say our cars have enough power. I like it Thumb
#modified996mk1
DJones
PostPosted: Sun Nov 24, 2019 11:39 pm    Post subject: Reply with quote
Some great work going on there..... looks lovely.
Darren.
2002 996 GT2 recreation in Nogaro blue
2017 Ferrari 488 GTB Nero black
2006 Ford GT40 Gulf Racing colours
1994 AC Cobra 427 Guardsman blue
MisterCorn
PostPosted: Fri Dec 06, 2019 6:58 pm    Post subject: Reply with quote
Engine is now finished, ready to bolt to the gearbox when the last of thw parts arrive in a week or so.
