991 : 2011- 18
997 : 2004- 80
996 : 1997-2005 33
Boxster : 1997- 25
Littlered996
PostPosted: Mon Aug 19, 2019 6:42 pm    Post subject: Centre console trim: black or tan? Reply with quote
After a failed attempt to “keep it original”, I have taken the plunge and installed a touchscreen double-din with CarPlay and all the gubbins.
It was a bit of a rush before holiday and the car needs to go back to have the cd drawers replaced with a cubby and the usb lead moved into said cubby.
My original thought was that I need a savannah cubby, but given the black climate control block, and the big black screen, I’m now thinking black. Thoughts?
After
 Filesize:  26.48 KB
 Viewed:  1319 Time(s)
Before
 Filesize:  1.3 MB
Dammit
PostPosted: Mon Aug 19, 2019 6:45 pm    Post subject: Reply with quote
Black without any doubt, I would do the vents and cup holder also
Moko
PostPosted: Tue Aug 20, 2019 6:16 pm    Post subject: Reply with quote
Another vote for Black but I would leave the vents and cup holder in original colour
BHZ661
PostPosted: Wed Aug 21, 2019 4:34 am    Post subject: Reply with quote
Black would be my choice thumbsup
PostPosted: Wed Aug 21, 2019 9:28 am    Post subject: Reply with quote
It's a personal thing but I'd be changing as many of the odd bits to black as I could.
Griffter
PostPosted: Thu Aug 22, 2019 6:16 am    Post subject: Reply with quote
You could recolour components in stages using a colour coat kit, then you can make your mind up as you go along!
Dammit
PostPosted: Thu Aug 22, 2019 7:42 am    Post subject: Reply with quote
Personally I like Savannah, but I think Porsche went too monochrome with it- take a look at an F355 interior which uses pretty much the same colour but contrasts it with solid black- looks awesome.
I’d be tempted to do something similar, black carpets, black underside to the dash maybe, keep the dash top and seats, door cards could be Savannah leather and black carpet etc etc
Littlered996
PostPosted: Thu Aug 22, 2019 8:47 pm    Post subject: Reply with quote
Thanks one and all. I think black cubby, definitely.
Dammit, I’m also a savannah fan. I think it’s very exterior-colour dependent. Definitely the right colour for a dark red exterior like mine. I have black carpets and think the “mostly black” centre console is the way to go. Not quite ready to give up my savannah air vents and cup holder though!!
Hughb
PostPosted: Fri Aug 23, 2019 10:15 am    Post subject: Air vents Reply with quote
..hope you don't mind me dangling this query onto your thread.... but it's in the same ball park as regards topic.
My 2003 C2 has silver air vents in the centre console which look the part ... but either side they are plain black which look cheap by comparison.
Does anyone know if it is possible to get these LH and RH vents with silver vanes?
kingston
PostPosted: Fri Aug 23, 2019 11:30 am    Post subject: Reply with quote
Buy the parts you want to turn black from ebay, so if you want to return to oem you can
Hughb - You can but you might as well just pop your fins out and spray them yourself, not hard to do
I really must learn to spell check and proof read my posts Smile
Hughb
PostPosted: Fri Aug 23, 2019 8:15 pm    Post subject: Air vents Reply with quote
Hi Kingston
Sounded like good idea, but checking the centre vent slats, they are actually metallic, not silver painted .... (if not solid metal, then metallised plastic, as in a metal plating process on the plastic, can anyone confirm this? )
I don’t think me and a silver paint aerosol are going to come up with anything to ‘look the part’ when comparing with my centre vent slats.
The thumb wheels appear to be similarly metallic. Can anyone shed any light as to whether the side vents are available in this silver metallic configuration?
Hughb
PostPosted: Fri Aug 23, 2019 8:16 pm    Post subject: Air vents Reply with quote
Double post
Hughb
PostPosted: Fri Aug 23, 2019 8:17 pm    Post subject: Air vents Reply with quote
Treble post, no idea how!
Hughb
PostPosted: Fri Aug 23, 2019 9:44 pm    Post subject: Side air vents with artic silver slats and thumbwheel Reply with quote
Following on from my query about trying to match the side vents (currently in black) to the rather nice metallic silver centre vents, I have done what I should have done in the first place ..... check out the Porsche parts suppliers to see if such a thing exists.....
It does! Great, let’s get some ...... just check out the price....
EXCUSE ME, WHAT!!, HOW MUCH??... £8 change from £1400 (one thousand four hundred pounds) ??!!
I’ve had an idea.....
....... darling, it’s my birthday soon, any chance you could get me a trinket for my new toy, the Porsche 996 (about which you are not that enthusiastic).... I was thinking of a couple of teeny weeny air vents, ...nothing very much, here’s the part number and the website address......you can order them and then it will be a surprise!
