991 : 2011- 18
997 : 2004- 80
996 : 1997-2005 33
Boxster : 1997- 25
cvega
PostPosted: Mon Aug 19, 2019 7:53 am    Post subject: Can't set the date... no, really can't! PCM2 Reply with quote
Hi folks, recently had a breakdown related to fuel pump and as battery is weak, i presume the car was in the garage for a few days - and thus the battery got dangerously low at some point....
Now, it won't let me set the date. It seems to be 1/3/2000...
Yes, I have a navigation CD and navigation seems to work fine. I can set the time, but not date. What the hell do i do? Very Happy
2003 996 C2
2017 Leaf 30kWh
gone: 2010 335d, 2007 Cayman S, 2008 Civic Type-R, 1992 MR2 Turbo ,1994 MR2 N/A
Harvster
PostPosted: Mon Aug 19, 2019 11:23 am    Post subject: Reply with quote
I have the same issue so would be very interested in the replies.
Mine has been like it for about 6 months and at the time I found out that the date CANNOT be set and sets automatically through the satellites. I had several suggestions to 'go for a drive' and 'leave it outside the garage', 'it needs more than 4 satellites to set'. All rubbish I believe because I have been up to 11 satellites I think and it still will not set.
Mine was also down to a battery issue, disconnecting it in fact.
Would like to get mine sorted too, mine is actually blank in between the time and the temperature on the PCM...
Porsche 911 996 4S 2003
Haywoon
PostPosted: Mon Aug 19, 2019 11:44 am    Post subject: Re: Can't set the date... no, really can't! PCM2 Reply with quote
I had the same problem - put in a sat nav destination and let it calculate the route and as if by magic it set the date correctly!
‘03 996 Turbo Coupe in Midnight Blue
‘02 996 4S Coupe in Polar Silver - sold
cvega
PostPosted: Mon Aug 19, 2019 12:09 pm    Post subject: Reply with quote
Good shout, I'll try that later - I never actually use this navigation to get anywhere Floor
2003 996 C2
2017 Leaf 30kWh
lethallegend72
PostPosted: Mon Aug 19, 2019 7:10 pm    Post subject: Reply with quote
I had the same issue on my PCM1.
As Haywood, I put in a destination, followed it and then everything was set correctly on the next ignition cycle after a sleep cycle..
PostPosted: Mon Aug 19, 2019 7:30 pm    Post subject: Reply with quote
This is for 997 really but similar i guess and all i know ..
http://911uk.com/viewtopic.php?t=135446
Mallone
PostPosted: Tue Aug 20, 2019 6:57 am    Post subject: Reply with quote
Had the same issue on my 986.
My thread over at Boxa.net: http://www.boxa.net/forum/topic/79995-pcm-21-date-incorrect/
I’ve learned to live with it!
Previously: 996 Carrera 2
Current: 986 Boxster S
cvega
PostPosted: Tue Aug 20, 2019 10:50 am    Post subject: Reply with quote
I tried setting destination (that works OK and it navigates so GPS is fine), but the date remains 1/3/2000.
To be honest I'm not too fussed, just odd that it happened now - I've had the car run out of battery loads of time before...
2003 996 C2
2017 Leaf 30kWh
PostPosted: Tue Aug 20, 2019 6:51 pm    Post subject: Reply with quote
https://www.orolia.com/resources/blog/lisa-perdue/2017/gps-2019-week-rollover-what-you-need-know
Devices over 10 years old that use this system will probably be affected after April 6, 2019. ....
And in this case after a flat battery .
Dont know
Paynewright
PostPosted: Wed Aug 21, 2019 8:23 am    Post subject: Reply with quote
I put the disc in and planned a route yesterday (boy that woman in the pcm is assertive!) and the date remained at year 2000.
I guess the Satellite GPS week number formatting explains it.
Demort - Thanks for researching the issue.
Ian
Haywoon
PostPosted: Wed Aug 21, 2019 6:15 pm    Post subject: Reply with quote
Yep mines bloody well defaulted to year 2000 now too.......must ignore OCD it’s only a freakin date..... frustrated
jamesdrew1975
PostPosted: Thu Aug 22, 2019 11:50 am    Post subject: Reply with quote
Glad it's not just mine then. By the sound of it from deMort's research it will likely affect all of us from now on if we need to swap out the battery or reset the PCM. I'll just have to get over the OCD aspect. Might put some black tape over the date display PC
2003 996 Turbo
Paynewright
PostPosted: Thu Aug 22, 2019 5:19 pm    Post subject: Reply with quote
Another reason to swap it out for a basic Continental DAB unit! Just the hurdle of fibre optics to deal with!
I never used to notice the date - now its wrong I look at it all the time!
