997.2 cab roof won''t open from key
qwerty911
19 Feb 2018
83
It is under warranty, but before I take it 100miles to nearest OPC is there anything I should check? Roof used to work fine from either key fob, but not now. The windows drop but the roof doesn't open, from either key. The red light on dash door lock/unlock switch flashes when fob button held so car getting a signal. Possibly has not worked since car had battery disconnected over winter, but don't see anything in the manual requiring a reset? Any suggestions?
Ignore the above. After reading a hundred posts I finally found the answer: remember to press the correct key fob button! the one indicating the rear. All summer I've thought it broken. Unbelievable, it must be age!
124,598
1,441,971
49,033
drthein
