991 : 2011- 18
997 : 2004- 80
996 : 1997-2005 33
Boxster : 1997- 25
Grey996
PostPosted: Fri Aug 16, 2019 11:32 am    Post subject: Stainless exhaust bolts and fittings, advice or link pls. Reply with quote
Hi all,
I’m off work the week after next so am getting the bits together to swap the exhaust. Last year I fitted Top Gear boxes but as it just scraped through its last mot omissions (diagnosed as failing cats) I’m going to fit new TG cats, manifolds and lambdas.
Can anyone share a link to the stainless steel manifold bolts or studs and the stainless clamps please?
2002 Porsche 996 C2
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Fri Aug 16, 2019 1:40 pm    Post subject: Reply with quote
There is a chance of the original manifold bolts snapping when removing and if you are pushed for time it might be worth planning for that event too.
Grey996
PostPosted: Fri Aug 16, 2019 2:01 pm    Post subject: Reply with quote
Thanks, yes I’m expecting the worst!
2002 Porsche 996 C2
Martin996RSR
PostPosted: Fri Aug 16, 2019 2:45 pm    Post subject: Reply with quote
I'm taking a break from my manifold bolt marathon as I type this. I've just finished replacing all my manifold bolts with stainless studs (well, I've got to pop the studs in on the remaining side, but it's raining and I'm doing it on my drive)
On the right side only two of the old bolts undid. On the left it was only one. All the rest had to be drilled out. I found the only use for my stud extractor was for snapping off a could of bolt shafts, saving having to cut them short as per the Stomski jig instructions. It's taken three days to do the job. If you have the money, it's well worth paying a specialist to do this for you as it's a total pig even with the right tools. Without the jig you wouldn't stand a chance.
I had previously replaced all the other bolts on the exhaust system with stainless and it meant that none of those gave me any trouble whatsoever.
Look on Ebay for stainless nuts & bolts, A2 stainless is fine. A lot of internet nerds will spout crap about metallurgy and stainless hardware not being suitable for all sorts of spurious reasons. The fact is, it works, it's strong enough, and it won't be brown dust in five years' time like the Porsche hardware.
Hertsdriver
2004 Porsche 997 Carrera 2
PostPosted: Fri Aug 16, 2019 3:16 pm    Post subject: Reply with quote
I know its been discussed here previously and people will say it isn't an issue, but generally speaking putting a stainless bolt or stud into an aluminium hole (ie the head of a porsche) is a very bad idea, as it will corrode, and if you try to remove it in the future and it snaps (as it will because they arent as strong as plain steel), it will be extremely difficult to drill out... far more difficult than a traditional steel bolt/studs that are currently a massive pain to do... if you do go down this route make sure you used brass nuts which are soft enough to get off the stainless thread without drama, dont use stainless or steel nuts...
I'm not sure whether titanium suffers from the same corrosion in aluminium as stainless steel?
sp1ke
PostPosted: Fri Aug 16, 2019 4:03 pm    Post subject: Reply with quote
I'm by no means knowledgeable on the subject, but I did find these articles which cover the risks of corrosion:
https://www.bssa.org.uk/topics.php?article=89
https://www.npl.co.uk/special-pages/guides/bimetallic-guide
As you'd expect from the National Physical Laboratory, the latter seems to provide pretty thorough coverage on the topic.
2001 996.2 C2
Grey996
PostPosted: Fri Aug 16, 2019 4:17 pm    Post subject: Reply with quote
Thanks Martin, I feel you’re pain! I’ll definitely be using a jig and I have a lift at home plus I’m too tight to pay a £100 a stud so I’m going in with fingers crossed!
Thanks for the comments and info re the type of studs, some good points from both sides. I’ll read the articles when I get a bit of down time later.
2002 Porsche 996 C2
Hertsdriver
PostPosted: Fri Aug 16, 2019 4:36 pm    Post subject: Reply with quote
The table in link 1 would appear to indicate that titanium is a worse idea than stainless... I had thought that maybe copper grease would be a good barrier but manifolds get far too hot for it to survive, is there a high temperature alternative that could be used on the threads?
maldren
PostPosted: Fri Aug 16, 2019 5:10 pm    Post subject: Reply with quote
[quote="Hertsdriver"The table in link 1 would appear to indicate that titanium is a worse idea than stainless... I had thought that maybe copper grease would be a good barrier but manifolds get far too hot for it to survive, is there a high temperature alternative that could be used on the threads?[/quote]
Sorry, copper grease is no good on ally either, similar corrosion issues. Ally grease is readily available (you should be using it on your wheel nuts!)
Mike
Martin996RSR
PostPosted: Fri Aug 16, 2019 5:26 pm    Post subject: Reply with quote
Hertsdriver, can you suggest a better alternative than stainless based on your experience?
Correct me if I'm wrong, but it looks like you're saying that using stainless fixings is a bad idea because of some stuff you found on the internet. The original Porsche fixings are made of plated mild steel. Their dissimilarity to aluminium means that there will always be galvanic corrosion of both materials. If you change one of those materials to one that doesn't corrode (yes, yes, I know stainless does corrode eventually, but for practical purposes it will last 10 years on an exhaust) then you leave yourself with half the corrosion problem that you would have had. Given the mild steel bolt will corrode as well as the aluminium bore it's in, the two will mechanically lock themselves together and at the same time as weakening the bolt. When torque is applied to the bolt it frequently take more torque than the weakened bolt can withstand to undo it. Ping! I heard that ping on nine out of twelve manifold bolts in the last couple of days. nooo
If you've used a stainless bolt, the corrosion of the bolt won't happen, so the mechanical locking won't happen, and the bolt will be pretty much as strong as the day you put it in.
You also say that stainless is softer and therefore is harder to drill into if the fixing snaps. This doesn't make any sense. If softer materials were harder then I would make a hammer out of playdough.
Sorry if any of this comes across as confrontational, it's just that having just spent three days skinning my knuckles underneath my car, partly in the pouring rain, it really grips my sh!t when people who haven't done the same (and I'm assuming you haven't, so apologies if you have) give bad advice based on hearsay. The consequence of this is that some poor ***** out there in the real world could read it and choose to either spend a fortune on wonder-bolts unnecessarily, or worse, install the original Porsche hardware, which will corrode to nothing in a few short years.
I use stainless in all sorts of applications across my 911, and having done this for six years, every one of the stainless fixings I've used has done its job and not caused the hole it's been screwed into to corrode beyond use. I've lost count of the mild steel fixings that I've had to drill out, hammer out, snap off, etc. I'll continue to use stainless based on my experience with it until someone comes up with a tested equivalent that works better and is reasonably comparable in price. If the stainless fixings I've used come back to bite me in the bum and my helicoil skills can't save me, I promise to come back here and own up.
Hertsdriver
PostPosted: Fri Aug 16, 2019 6:04 pm    Post subject: Reply with quote
Hmmm..
Can I advise on something better? No and I’m not sure I said I could. I am learning from what I’ve read here and elsewhere and trying to participate in the discussion, apologies to you if you think that my participation in this thread warrants your abuse and ridicule.
Was it my comment about using brass nuts rather than stainless that ‘got your giat’
I’m not sure I said stainless was soft did I? Perhaps you can point out where I did?
It certainly isn’t soft, it’s significantly harder than steel but it doesn’t have the same torsional strength as steel, because it’s far more brittle. That’s why I personally don’t like to use it in situations that require strength (like wheels, and to some degree, replacing bolts in places that require torque).
If I were to proffer an apparently (un)educated opinion, I would suggest that a good grade steel stud, installed with an anti galvanic grease (alloy grease as mentioned by another) installed at a sensible torque and then fitted with brass nuts would probably be more than adequate. It certainly used to work very well on older cars, and despite the increase in technology I am not sure exhausts on a 996/997 get significantly hotter than they do on older performance cars, or perhaps you can put me right on that?
My opinion on ‘what went wrong’ is that Porsche used cheap bolts, both in the fact that it’s clearly cheaper to used a bolt than a stud and washer/nut, and the material is obviously substandard.
I am interested to hear about how ‘the mild steel bolt will corrode as well as the aluminium bore’, as that seems to fly against the laws of physics for galvanic corrosion...
Martin996RSR
PostPosted: Fri Aug 16, 2019 6:38 pm    Post subject: Reply with quote
You mentioned in this passage that stainless bolts 'aren't as strong' but will also be difficult to drill out. In my very recent experience, the weaker something is, the easier it is to drill. In your reply you've moved over to brittleness vs hardness which makes more sense.
I'm not sure where to start on how replacing a mild steel stud with a non-specific 'good grade' of steel (though naturally not stainless) isn't exactly a quantumn leap in sensible. I like your brass nuts though. thumbsup
Hertsdriver
PostPosted: Fri Aug 16, 2019 6:42 pm    Post subject: Reply with quote
Just a ‘sorry, I read back and you didn’t actually say it was soft’ would have sufficed. Floor
If Porsche had of used plated steel studs and brass nuts, we wouldn’t even be having this conversation, as the brass nuts would have unwound from the stud, and there would be no reason to have to drill anything out (unless the grade of steel used was so poor that it rusted away, which is a distinct possibility...). So what would I use? Probably a stainless stud with a brass nut. There is clearly no need for titanium, I’m sure we can both agree on that, but I maintain that a good quality, possibly galvanised or zinc plated steel stud together with a brass nut would most likely suffice Thumb
In reality this is one of those situations where we are going overboard because of the pain and/or cost of sorting the issue, so the natural want it to replace with something ‘better’, in reality it’s unlikely anyone changing a manifold will do it again, so all the effort is more than likely only if benefit to the next owner.
yo_clarkie
PostPosted: Fri Aug 16, 2019 9:21 pm    Post subject: Reply with quote
Mine replaced with Inconel.
https://en.wikipedia.org/wiki/Inconel
I used to be a welder in a very hash marine and refinery environment and gained considerable respect for its ability to take heat and cooling and not rot or warp...
There are plenty of suppliers, not particularly cheap, but i would expect them to outlast the car
https://www.ebay.com/itm/INCONEL-TURBO-STUD-COPPER-LOCK-NUT-FOR-MANIFOLD-SET-OF-12-M8-X-1-25-X-45MM/182588294597?hash=item2a831c45c5:g:zq8AAOSwIKZdRHwE
maybe as above link? I have some 718 bolts that i used in my bits bin, but the above are studs and copper locking nuts, prob a fairly good choice.
Or as mentioned above, go S/S as its unlikely to be needed again in the life of the car.
2003 996 C4S in Silver, Manual, PSE, new in UK, now in New Zealand
Mods so far: K&N induction, Kenwood Navigation and AMP, LN Engineering IMS, fully replaced suspension with new factory parts
Teffers
PostPosted: Mon Aug 19, 2019 9:47 pm    Post subject: Reply with quote
Didn't Poppopbangbang come up with a solution?
http://www.porschetistuds.co.uk/
Tracktard. French obsession.
Counter Of Beans
PostPosted: Tue Aug 20, 2019 8:43 am    Post subject: Reply with quote
Is this uniquely a Porsche problem? What do other manufacturers do, such as McLaren or Ferrari for instance? Or in aerospace?
It certainly seems to me that Porsche have "gone cheap" in all the nuts and bolts around the exhaust, and replacing them is beyond the skills of the average DIY'er - or at least in Martin's case it drives us, err, nuts.
I'm Mike and I count beans for a living.
Windy101
PostPosted: Tue Aug 20, 2019 9:46 am    Post subject: Reply with quote
No longer making them is appears.
Could try
http://www.porschetibrides.co.uk/
Dagerous
PostPosted: Tue Aug 20, 2019 2:38 pm    Post subject: Reply with quote
I've just had my manifolds replaced and the mounting bolts replaced with Popopbangbang's titanium studs (And non-titanium K-Nuts). I'm no metalurgist and fully accept that this solution is very expensive and probably a wildly over the top solution but you know what? I don't care. The many (And detailed) explanations PPBB provided impressed me and every time I look under the car I see those sparkling bits of jewellery (Be under no illusion, the studs are a work of art!) I get a small warm an' fuzzy feeling.
A point also worth noting is that I had the work done at Brookspeed in Eastleigh, Hampshire and 10 out of the 12 studs sheared. Luckily Brookspeed have a local guy with the engineering kit to drill them out (Far better than me with a cordless B&Q drill and a dedicated drill guide). Suffice to say I would rather not go through that again (Though truth be told the drilling out work was less that I had expected). It wasn't cheap but damn I'm glad I didn't try and do it myself.
So that's my story. Is the expense justified? Probably not, but for myself I'm glad that is now in the category of "A good job well done". You can also be certain that if I ever decide to sell the car (HIGHLY unlikely!) I'll be sure to tell and show the new owner the glorious Titanium studs shining away under the engine.
Martin996RSR
PostPosted: Tue Aug 20, 2019 5:51 pm    Post subject: Reply with quote
I part-own an aeroplane and it has a flat four six litre engine with Ali heads. as it’s an American aeroplane we use aircraft quality AN fasteners throughout. The exhaust manifold studs are plain steel AN, which is cadmium plated rather than zinc plated like the Porsche fasteners. Cadmium provides better corrosion resistance, but they still rust and require replacement every few years. As for the strength of the studs, they are 116,000 psi, which is there or thereabouts the Porsche ones, and about 15-20% stronger than stainless ones.
If anyone reading this has their heart set on using mild steel studs, then cadmium plated ones are the way to go, but ultimately, stainless, Ti, or inconel are the only practical way to ensure the studs aren’t a service item. Also, aircraft grade fasteners are so pricey that you would be spending less on stainless and not much more if you went for Ti.
In essence, yes, Porsche went cheap and specced fasteners all over the car to a price without any regard to future serviceability. As owners it’s down to us to replace those fasteners with something that will still function in five years time. I’m sure Demort of this parish will back me up when I say that even cars as recent as the 997.2 now have this problem, so it’s not like it was just a bean counter having his way with early 996s.
PostPosted: Tue Aug 20, 2019 6:22 pm    Post subject: Reply with quote
Consider yourself backed up young man Very Happy
Rule of thumb .. the newer the car the faster the exhaust ( mainly flange ) studs nuts corrode and let go .
i've seen almost nothing left of a 993 exhaust bolt but it was original and still holding firm .. although to be fair i think the two halves of the exhaust had rusted together and would never come apart !
986 early version .. i did one today .. 130k miles and original studs .. not blowing but so close we had to replace .
I've already replaced 991 / 981 flange studs with 997 being very common .
Chocolate springs to mind .
To be fair .. well a little bit .. we have pretty awful weather and we salt our roads .. we also have a lot of coast line , salt air ..
All of these have a huge impact on not just the exhaust bolts ...
You would have thought that our market would have more protection due to this .. after all .. even the Romans hated our weather so it's not exactly a new thing .
