997 : 2004- 62
996 : 1997-2005 29
Boxster : 1997- 26
SimonBash
PostPosted: Thu Aug 15, 2019 8:05 pm    Post subject: Coolant level Reply with quote
Hi All,
Collected my car from OPC Cardiff today after Monday’s drama so I have a new water pump.
I’m now paranoid about the coolant level....after 4 hours of driving and with the engine off but hot the level appears to be below the ‘min’ line, is that normal? Will then level go up once the engine has fully cooled down?
jl-c
PostPosted: Thu Aug 15, 2019 8:12 pm    Post subject: Reply with quote
Understandable, kiss it goodnight and check in the morning when it is cold. Smile
Top up then if still low. You will probably find all is OK. Just keep an eye on it for a few days. Don't overfill and topping up with just water is OK for less than a pint or so. Coolant mix is preferable though Thumb
Geezer 911
PostPosted: Fri Aug 16, 2019 4:26 am    Post subject: Re: Coolant level Reply with quote
SimonBash wrote:
Hi All,
This is common you may just have an airlock. This happened a few times to me over the last couple of years,it tends to sort it self out. But yes do keep an eye on it.
Did the OPC check the coolant pipes when it was in their care to make sure there was no leaks? My Indy always checks the coolent pipes when I take the car in hoping for an up sell...
MaxA
PostPosted: Fri Aug 16, 2019 5:53 am    Post subject: Reply with quote
I had to top up the coolant a full year after the coolant flush and replacement with about 1l of mixture. The engine seems to have a lot of nooks and crannies...
Hamster75
PostPosted: Fri Aug 16, 2019 9:52 am    Post subject: Reply with quote
When I had hoses changed on my 997.2 they drained & flushed, I had to top up couple of times about 1/2 litre, did make me a bit paranoid, do it when cold it will settle down.
991.1 C2S Red
997.2 C4 White
924 Blue
SimonBash
PostPosted: Fri Aug 16, 2019 10:05 am    Post subject: Reply with quote
Thanks all - is there a specific coolant I should use? Sorry for the basic questions!
Porschekit
PostPosted: Fri Aug 16, 2019 10:14 am    Post subject: Reply with quote
Also make sure you actually take the cap off to check the coolant level (when cold). I looked at mine for months without taking the cap off when I first got my car and then realised I was looking at an old "tide mark" on the inside of the vessel. When I took the cap off I couldn't see any liquid and had to top it up with at least a litre of coolant...... Embarassed That and a twig stuck in the radiator fan blade revealed why she was running a little hot..... Grin
997.1 C4S Meteor Grey Metalic
SimonBash
PostPosted: Fri Aug 16, 2019 10:19 am    Post subject: Reply with quote
Thanks Thumb assume any coolant from somewhere like Halfords is OK?
Porschekit
PostPosted: Fri Aug 16, 2019 10:23 am    Post subject: Reply with quote
All places that sell coolant will have a reference book that shows which coolant to use for a particular vehicle, it's pretty straight forward, and as usual not cheap.... nooo
MaxA
PostPosted: Fri Aug 16, 2019 10:46 am    Post subject: Reply with quote
I just popped into my local indy who siphoned off a litre of coolant from their big tank for 10eur.
easternjets
Watkins Glen
PostPosted: Fri Aug 16, 2019 12:12 pm    Post subject: Reply with quote
Do you know if the system was completely drained down when you had the pump done?
I did my pump on a Gen 1, sod of a job and got advice from DeMort on refilling, you may have an airlock but a good brisk drive should sort that out.
Obvious things to look out for are puddles of pink fluid on the drive/floor, if there are non then it's fair to say you have no leaks.
Check your levels when cold and make sure they are half way between the min/max marks, fill with the pink fluid which you can buy premixed from ECP, it's about £3 a ltr.
997 Turbo Gen 2
997 Turbo Tiptronic S
Porsche 968 Coupe 1992
Porsche 928 S4
Porsche 911 3.2 Carrera 1985
997 Coast
PostPosted: Fri Aug 16, 2019 2:26 pm    Post subject: Re: Coolant level Reply with quote
SimonBash wrote:
Hi All,
My water pump went - last week - incontinent = PANIC
Used Lockton policy to ship it over to Unique Porsche at Bolton
Done collected Sunday \ mines normal - if you are worried go back.
So many throw away remarkes re bore scores etc - water pumps go - ENJOY
PostPosted: Fri Aug 16, 2019 5:42 pm    Post subject: Reply with quote
Not much i can add other than what's already been said ..
Check it when cold and top up if needed ( water is fine due to the shear volume of coolant it won't drop the antifreeze content by much ) it sounds like there was a small airlock which has now cleared ... not unusual shall we say and a bit difficult to predict ..
Some cars are fine after a job like this and others hang onto an airlock for a good few miles .
we tend to tell customers at work .. check it over the next few days until it settles .
Obviously never open the cap with a hot engine .
Indy Mechanic .
SimonBash
PostPosted: Fri Aug 16, 2019 6:56 pm    Post subject: Reply with quote
Thanks all much appreciated Thumb
chunkymonkey1982
PostPosted: Sat Aug 17, 2019 3:51 pm    Post subject: Reply with quote
Can water be added or does it have to be distilled water in the 50/50 mix with coolant ?
PostPosted: Sat Aug 17, 2019 3:53 pm    Post subject: Reply with quote
I've always just used tap water......and my engine hasn't exploded yet.
SimonBash
PostPosted: Mon Aug 19, 2019 4:36 am    Post subject: Reply with quote
Thank you. Left the car until it was dead cold (over 24 hours) and the level remained just below minimum.
Topped up with 50/50 coolant/water mix to between the min and max indicated levels. I have re-checked after use and it’s stayed at the same level so far but will keep an eye on it.
i_should_coco
PostPosted: Mon Aug 19, 2019 8:25 am    Post subject: Reply with quote
My water pump failed earlier in the year. I had to top up just once after I drove home from the garage. Seems to be fine now and hasn't moved since.
