991 : 2011- 19
997 : 2004- 74
996 : 1997-2005 33
993 : 1993-1998 7
Boxster : 1997- 33
Cayman : 2005- 20
P911X50
PostPosted: Tue Aug 13, 2019 6:39 pm    Post subject: 2nd gear pop out - 996tt X50 Reply with quote
Hi
I have a problem with the gearbox. When decelerating towards a roundabout in 2nd gear my car pops out of 2nd gear.
It doesn't happen on most occassions, only sometimes when driving down hill towards a roundabout.
Clearly, there is a fault. Any ideas on costs to repair, it's a 996 X50 (apparently, they have stronger gearboxs)
All advice greatly appreciated.
thumbsup
Porsche 996 Turbo X50 with 9e exhaust,
BMW M6 V10,
Previous
Evo 4 with Evo 8 MR Engine 360 bhp - Road Legal Track car
Previous
MR2 Turbo 280 bhp - Road Legal Track Car
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Tue Aug 13, 2019 6:43 pm    Post subject: Reply with quote
They are completely different to the standard G96 gearbox. I have a spare gearbox from a 36k car in great condition if needed, but it will be cheaper to get yours fixed. I would call Matt at Fearnsport.
P911X50
PostPosted: Tue Aug 13, 2019 7:27 pm    Post subject: Reply with quote
Hi
Someone was telling me that it was the synchro hub? is that a big job? any ideas on cost?
BMW M6 V10,
Previous
Previous
MisterCorn
PostPosted: Tue Aug 13, 2019 7:34 pm    Post subject: Reply with quote
Another option.
https://sportsandclassic.com/gearbox-repairs-2/
My gearbox would be £5k
Mac996t
PostPosted: Tue Aug 13, 2019 11:24 pm    Post subject: Reply with quote
Google 996t 2nd gear pop out, loads of stuff comes up, mainly on the American forums, strangely it seems to be quite rare in the UK but very common in the US
Quick search turned up this too
http://www.gboxweb.com/996shimtip.html
alpinaman
PostPosted: Wed Aug 14, 2019 3:59 pm    Post subject: Reply with quote
Its a common fault,my C4s did it too.
I think i was quoted just over £2000 for repair,albeit a few years ago now.
sportsandclassic
Approved Trader
PostPosted: Thu Aug 15, 2019 8:13 am    Post subject: Reply with quote
The 2nd Gear "pop-out" has been around on these cars since almost new, this includes the 996 C2/C4/C4S/GT3/GT2/Turbo models. We have been repairing these for 14 years now.
The "pop-out" will 99% of the time occur like you have described as the gear is coasting and not under engine load. When under load the inertia and angles of engagement teeth on the gear and shift sleeve actually force them together to interlock but when you take your foot off the throttle the gear train is oscillating with flywheel dampening, road speed, through the differential and there are a number of things to keep that gear engaged - spring pressure of the selector rod, engagement depth of shift sleeve, gear stack height etc.
One of the main issues is that the 2nd gear height is too low from manufacture - this can be corrected and is 1 of the modifications we do when re-build these gearboxes.
The gear can also have too much running clearance on the needle roller support bearing so again this needs to be corrected to minimise gear flutter on coast/over-run.
Chances are it will require a few modifications BUT it could end up with new gear/shift sleeve and synchro set for 2nd gear as it could be damaged now.
These Gbox detents are merely a short term fix - they allow the shift arrestor to travel further to slam the shift sleeve into the engagement ring on the gear , this creates a few issues in that the shift rod is now not held correctly as it has been forced past where it should be and you are now over throwing every other gear in the gearbox. On 3rd/4th gears the engagement rings have end stops and when these Gbox detents are installed the shift sleeve on 3rd/4th damages and breaks these off the gear allowing now a foreign object to cause damage- yes sure the magnet may get hold of it but there is not just one that breaks off and I have seen the damage these "wonderful upgraded" detents cause.
Rough cost for 2nd gear fix is £2750.00 plus VAT and this includes us removing and installing the gearbox. (This includes new parts for 2nd Gear)
Sports and Classic Ltd
Sports and Classic - Porsche Service & Maintenance
