991 : 2011-2019 0
997 : 2004-2012 0
Boxster : 1997- 22
Mookin
PostPosted: Tue Aug 13, 2019 5:01 pm    Post subject: 911 amateur club question regarding central locking/alarm Reply with quote
Hello guys,
7 months into ownership and really starting to gel with the car. I’m addicted. Car is crazy capable and I will never get close to its limits with my skills. Quick question, I think I read about this somewhere before but can’t find an answer online. If I leave car for approx 4-5 days it won’t open off the central locking key fob button and I have to use the key manually in the door lock to open, invariably setting off the alarm briefly when I start up. Is this normal? I thought I read somewhere the fob goes on security shutdown if unused for a few days?I am presuming there is a knack? Hopefully not a fault. I should obviously be using the car more!
Ocean Blue Metallic Porsche 996, 3.4, Carerra 2, Manual, PSE, 2000.
Magic919
PostPosted: Tue Aug 13, 2019 5:27 pm    Post subject: Reply with quote
Unlock/lock with the key. Then use fob as normal.
997.2 C4S PDK
moorhouse
PostPosted: Tue Aug 13, 2019 5:30 pm    Post subject: Reply with quote
Mine is a 996.2 but assume it will work the same - basically I open and close the central locking manually with the key (drivers door, leave the door closed) and this seems to wake the system up (interior light goes on etc). Then works fine with the fob to disable alarm and unlock doors as normal. Haven't had the alarm go off yet.
Cheers...…...Ian (EDIT - obviously last poster can type faster than me!!)
40th Year Anniversary #698
ian_alex
PostPosted: Tue Aug 13, 2019 6:02 pm    Post subject: Reply with quote
My 996.2 sometimes sets off the alarm after turning the key in the lock and sometimes it doesn't!
In either case subsequent lock/ unlock with the remote returns things to normal, with no subsequent adverse effects.
kurlykris
PostPosted: Tue Aug 13, 2019 6:08 pm    Post subject: Reply with quote
On my 996.1, when the car/alarm/fob has gone to sleep, unlock the car by turning the key in the lock clockwise to unlock, you then have 10 seconds to turn on the ignition before the alarm goes off. If you turn the key anti-clockwise then clockwise the alarm will go off instantly when you open the door.
My fobs are both dead at the minute, so I am using the key all of the time.
2006 Boxster S sport chrono
2010 Mercedes E350 AMG Sport
PostPosted: Tue Aug 13, 2019 7:02 pm    Post subject: Reply with quote
Totally normal as everyone has said .. its deep sleep mode which is the cars way of trying to prolong the battery life as long as possible .
Mookin
PostPosted: Tue Aug 13, 2019 7:17 pm    Post subject: Reply with quote
That’s great! Thanks fellas. Knew it would be something simple(for a simpleton like me)
NickHappy
PostPosted: Wed Aug 14, 2019 5:58 am    Post subject: Reply with quote
When in “sleep mode” turn the key in lock to unlock and then press button on fob whilst key is still in lock. Alarm won’t go off Thumb
I know what you mean with this - it wakes up the neighbours whilst going for an early morning blast if not.
997 turbo Manual.
996 turbo Manual. ex.
