991 : 2011-2019 0
997 : 2004-2012 0
Boxster : 1997- 22
PostPosted: Mon Aug 12, 2019 6:15 pm    Post subject: Query re Rear brake pads and AV dampers. Reply with quote
My car needs new rear brake pads but whilst researching prices etc I've come across an item called 'Anti Vibration Dampers'.
Is it necessary or advisable to replace the AV dampers at the same time as having new pads fitted Question
Needless to say I won't be doing the job myself but I'm curious as to how long a job it would be if done by someone who knows what they're doing.
With thanks in anticipation.
PostPosted: Mon Aug 12, 2019 6:28 pm    Post subject: Reply with quote
Under 2 hours.
jonno_
2005 Porsche 997 Carrera 2S
PostPosted: Mon Aug 12, 2019 6:35 pm    Post subject: Reply with quote
Hello Terry
From memory there are 8 needed on the rear axle, 2 per pad on my C2S, not 100% on the turbo. They're just a couple of quid each, so worth doing for peace of mind alone.
There are 2 sizes iirc. Don't forget you'll need wear sensors x 2 as well. Again, not expensive.
No more than 1 or 1.5 hours labour plus parts and vat I'd say.
PostPosted: Mon Aug 12, 2019 6:40 pm    Post subject: Reply with quote
I would assume they are the pad locating plates .. double sided tape on a plate that locates inside the caliper pistons ..
If so then they would be replaced as standard when ever replacing the pads .
Discs and pads replacement is 1.5 - 1.6 hrs depending on model and front or rear .
Billy Bumpsteer
PostPosted: Mon Aug 12, 2019 8:26 pm    Post subject: Reply with quote
About £16 each................4 per car Surprised
PostPosted: Mon Aug 12, 2019 8:29 pm    Post subject: Reply with quote
Exactly.......a couple of quid each Grin
PostPosted: Mon Aug 12, 2019 8:35 pm    Post subject: Reply with quote
Thanks all.
4 dampers for the rear = £80.26 (incl VAT) from Design 911, i.e dearer than the Brembo pads I've already bought !!
Re-reading some old threads and the advice above suggests they should be done. I can get the sensors for c£22 so will get them done too.
Pickse
PostPosted: Thu Aug 15, 2019 4:03 pm    Post subject: Reply with quote
£15 each plus vat (£72) at Bell & Colville who always seem to come in a bit less than D911.
https://www.deroure.com/diagrams.asp?MAK=3&MDL=30&TBL=3787&SMA=0&SMO=0&ST=99610662179&SC=1
Pickse
03 Arctic Silver 996T Tip S
Now 9E38 - An improved! 996T
Hertsdriver
2004 Porsche 997 Carrera 2
PostPosted: Fri Aug 16, 2019 9:05 am    Post subject: Reply with quote
£45.25 delivered from carpartsforless.com.....
use code MID20 for 20% discount
You wont need new sensors, the old ones come out easily without damage
 Filesize:  136.58 KB
 Viewed:  294 Time(s)
