997 : 2004- 57
Carrera SC : 1977-1983 3
Boxster : 1997- 24
Cayman : 2005- 22
Cayenne : 2003- 7
k11pol
PostPosted: Sat Aug 10, 2019 5:39 pm    Post subject: Mirror adjustment when in reverse ? Reply with quote
Does anyone know if it is possible to adjust the mirror position when reverse is selected ? Currently when in reverse the mirror angles downwards towards the ground but it’s not low enough for me to see the wheels or pavement.
Magic919
PostPosted: Sat Aug 10, 2019 6:40 pm    Post subject: Reply with quote
If it’s like the 997, then adjust when in reverse and save with the memory buttons.
997.2 C4S PDK
PostPosted: Sat Aug 10, 2019 6:56 pm    Post subject: Reply with quote
When in reverse and the mirror has lowered .. manually lower it to where you want .. see if it retains the position the next time you try it .
Indy Mechanic .
k11pol
PostPosted: Sat Aug 10, 2019 7:24 pm    Post subject: Reply with quote
Thanks guys , had a few tonight so will give it a go in the morning 👍
findtom
PostPosted: Fri Aug 16, 2019 10:39 am    Post subject: Reply with quote
I think this only works with the 18way seats.
www.findtom.com
k11pol
PostPosted: Fri Aug 16, 2019 10:55 am    Post subject: Reply with quote
I have the 18 way seats so that’s good news. I haven’t actually been near my car yet to test this but will try it soon.
pvr
PostPosted: Wed Sep 18, 2019 1:47 pm    Post subject: Reply with quote
You have to set that setting in the PCM to let it do that.
Nice part is that you can define how much and type of tilt you want, it remembers that as well.
911-50 (1835), X5M, Abarth 595 Comp, Golf Clipper, Jeep
k11pol
PostPosted: Thu Oct 31, 2019 6:01 pm    Post subject: Reply with quote
PVR - I’ve not used the car for a long time but was trying tonight to use the PCM to set the mirror position for reversing but haven’t seen anything to prompt me though I have learned a few other things. So can you explain which menu and how to get there please, thanks.
pzero
PostPosted: Thu Oct 31, 2019 6:41 pm    Post subject: Reply with quote
A full explanation is given on page 121 of the driver's manual.
991.1 Carrera GTS
k11pol
PostPosted: Thu Oct 31, 2019 6:48 pm    Post subject: Reply with quote
That’s only the option to automatically lower the mirrors towards the kerb when engaging reverse or to switch the function off. What I’m trying to do is adjust the lowering of the mirror further downwards as the current setting doesn’t go low enough to show the kerb, it stops quite a bit short and it’s very difficult to see the kerb. The passenger side is perfect but the drivers side not so.
pzero
PostPosted: Thu Oct 31, 2019 6:58 pm    Post subject: Reply with quote
k11pol wrote:
Perfect , thanks 👍
It states that this is for those vehicles fitted with the memory function.
Here's to looking down thumbsup
991.1 Carrera GTS
k11pol
PostPosted: Thu Oct 31, 2019 7:03 pm    Post subject: Reply with quote
Sorry just updated my reply
pzero
PostPosted: Thu Oct 31, 2019 7:32 pm    Post subject: Reply with quote
Hmm, other than sitting on a cushion you might be out of luck with that.
991.1 Carrera GTS
k11pol
PostPosted: Thu Oct 31, 2019 7:44 pm    Post subject: Reply with quote
I’m sure there’s a way round it as Porsche do things to detail and will have considered people’s different heights. I’m taller than average so there must be a solution. I will ask them direct , I didn’t see any Porsche cushions for sale when I was in this week for my MOT 😂😂
