991 : 2011- 19
997 : 2004- 74
996 : 1997-2005 33
993 : 1993-1998 7
Boxster : 1997- 33
Cayman : 2005- 20
911-C2
PostPosted: Wed Aug 07, 2019 10:31 am    Post subject: Rear Tyre recommendations - 285/30/18 Reply with quote
Hello,
There doesn't seem to be a lot of choice in the correct size tyre for my car - 285/30/198.
I have some Pirrelli on the rear currently with about 5mm tread but they definitely require replacement as are lethal in the wet. I assume the 12 year old rubber is past its best.
Reading around, even new Pirelli don't seem to get a great write up.
What is everybody's go to tyre out of the choice I can find available:
Michelin PS2 N3
Bridgestone Potenza S02A
Pirelli P Zero Rosso N4
Michelin Pilot Sport Cup 2
I am not bothered about the N rating, is the above the only tyres available to choose from?
Thanks,
James
cvega
PostPosted: Wed Aug 07, 2019 10:38 am    Post subject: Re: Rear Tyre recommendations - 285/30/18 Reply with quote
Surprised Surprised Surprised Surprised Surprised
911-C2 wrote:
Michelin PS2 N3
Thanks,
James
Yeah you're kinda limited for this size. You could go 275/35/18 or 295/30/18 as well.
2003 996 C2
2017 Leaf 30kWh
gone: 2010 335d, 2007 Cayman S, 2008 Civic Type-R, 1992 MR2 Turbo ,1994 MR2 N/A
TurboRob
PostPosted: Wed Aug 07, 2019 10:50 am    Post subject: Reply with quote
Going through the same deliberations myself at mo -
275/35r18 means a wider choice/cheaper tyre, e.g. Michelin Pilot Sport 4 ~£150 fitted ea.
996.2 C2
Osh
PostPosted: Wed Aug 07, 2019 12:49 pm    Post subject: Reply with quote
Depends on what you want them to do. If you want stickyness then the above is a good list; if you want long wearing the Falken are very good.
Had a set on my C4S and they lasted 18 months. Thumb
Osh
PostPosted: Wed Aug 07, 2019 1:18 pm    Post subject: Reply with quote
I swear by these. Excellent value for money and stick like shoite to a blanket.
 Filesize:  621.31 KB
 Viewed:  2150 Time(s)
rdodger
PostPosted: Wed Aug 07, 2019 2:20 pm    Post subject: Reply with quote
I put Bridgestone N rated on mine recently. Replacing 7 year old Michelin.
I think whatever new tyres you put on will be a world better than any that are 5 + years old. At 12 years they must be as hard as steel!
I am very pleased with them and can recommend them quite happily. The ride feels a little more compliant and the grip levels higher and the transition to slip predictable (very small amounts of slip! I'm not Monkey Harris!)
patpending
PostPosted: Wed Aug 07, 2019 2:35 pm    Post subject: Reply with quote
https://www.carbibles.com/best-all-season-tires/
Always been a big fan of the German manufactured Goodyear’s and if they have them in your size I’d fit them in a heartbeat.
They turned my previous 993 into a rock solid car in the wet that defied anything any other previously fitted tyre could.
cvega
PostPosted: Wed Aug 07, 2019 2:41 pm    Post subject: Reply with quote
Interesting. How are the sidewalls? are they stiff enough?
I've put Uniroyal RS3's on my car and I regret this. Soft as marshmellows, even though they're good in the rain.
2003 996 C2
2017 Leaf 30kWh
PostPosted: Wed Aug 07, 2019 2:49 pm    Post subject: Reply with quote
XL - extra load. They're fine. Only problem I have now is I can't get the back end out.
cvega
PostPosted: Wed Aug 07, 2019 2:54 pm    Post subject: Reply with quote
rs3's are XL too but way too soft.
2003 996 C2
2017 Leaf 30kWh
maldren
PostPosted: Wed Aug 07, 2019 4:18 pm    Post subject: Reply with quote
I went with PS2s but after speaking to CG during my suspension set up, I slightly wish I had gone PS4s in 275/35/18, a more modern tyre and apparently very good.
Mike
baldguy
PostPosted: Wed Aug 07, 2019 5:40 pm    Post subject: Reply with quote
I had PS4 on my 997TT and I found them very hard...I run PS2 on the C4 and I think the same on the Cayenne... its Michelin or Conti for me... however I agree with Falkens... a great tyre.. very sticky for a great drive... had them on previous AMGs....
958 Cayenne Turbo - Amethyst
996 Carrera 4 - Lapis
skinny_monkey
PostPosted: Wed Aug 07, 2019 8:16 pm    Post subject: Reply with quote
On my PS4 You turned in and there was a bit of a delay until the tyres settled into their steady state grip so you would need two bites of the cherry on entry. CG agreed when I went back following my initial set up (we ran out of time for a proper assessment) and added a bit of camber to stop them rolling in hard cornering and took off some toe in at the rear to help the response. Pete said that actually a few customers with the PS4 had reported something similar.
However with that alignment now done, the PS4 are epic.
911-C2
PostPosted: Wed Aug 07, 2019 8:33 pm    Post subject: Reply with quote
Thanks for the input, I'll probably go for the Bridgestone in the correct size.
Martin996RSR
PostPosted: Thu Aug 08, 2019 1:22 pm    Post subject: Reply with quote
My strong preference for rears is the cheapest and hopefully hardest tyre I can find in 255 section. That way I get to do at least a bit of steering with the throttle. You guys on 285+ section modern rubber are missing out on a world of fun. Massive tyres to look nice though.
911munKy
PostPosted: Thu Aug 08, 2019 6:26 pm    Post subject: Reply with quote
I got 14,000m out of my last set of Conti SC2 rears, not bad for a 996, so if you rack up the miles it’s also worth considering the mileage you’ll get out of them when comparing options, if you replace tyres more frequently it can get expensive.
2000 C2 996
skinny_monkey
PostPosted: Thu Aug 08, 2019 9:18 pm    Post subject: Reply with quote
Whereas i got 5000 miles out of my rear conti SC5...!
Jamesx19
PostPosted: Sat Aug 10, 2019 10:39 pm    Post subject: Reply with quote
Does alot of the milage depend on rear camber / toe settings?
I was wearing out the inner shoulder of my Michelin PS2 's at an alarming rate before I adjusted rear camber from 1deg 30" (which slipped to 1 Deg 40') to 1 Deg 18" ish. Now lasted 10,000 miles of mixed driving, with maybe 1-2,000 miles left till legal minimum.
1998 C2 Manual + The Full Hartech.
Martin996RSR
PostPosted: Sun Aug 11, 2019 3:48 pm    Post subject: Reply with quote
Rear wear is massively dependent on toe + camber. It's crucial to get it set up right (i.e. not too much of either, and certainly no toe-out) to preserve the tyre.
Jamesx19
PostPosted: Sun Aug 11, 2019 7:55 pm    Post subject: Reply with quote
Yeah suspect as much.
Just seen this year's Evo tyre test.
225/40 r18 size was the test tyre..,... Makes it both interesting and relevant to us as it's the front tyre size for a lot of us.
Pirelli shock winner! (To me anyway)[/i]
