997 : 2004- 62
Carrera SC : 1977-1983 3
Boxster : 1997- 24
Cayman : 2005- 20
Cayenne : 2003- 7
trendy old 997.2 driver
PostPosted: Tue Aug 06, 2019 7:52 pm    Post subject: 997.2 damaged plug on wiring loom that connects MAF Reply with quote
Hi, on my 997.2 Carrera 4S I have completely damaged the plug on the wiring loom that connects to the MAF. The MAF is fine, it is a badged Bosch part. The loom came loose and got mangled by the drive belt. I expected I would simply get a new plug and remake the wire connections and be right as reign. Unfortunately it seems Porsche don't sell the plug separately and I have to purchase a complete new engine loom. Am I missing something? There must be a simpler fix, or a supplier who will simply sell me the plug surely? The plug has 5 flat female slots for spade connections and is apparently a special for more recent porches, including the Boxster.
Does anyone have any suggestions I can't afford £900 for a new loom but the car is off the road in the meantime.
Does anyone know the OEM of the plug? It is not Bosch! I have tried the usual breaker yard websites and even a wiring loom repair specialist in Reading, all to no avail.
Any help/ideas gratefully received.
Thanks in advance.
PostPosted: Tue Aug 06, 2019 8:03 pm    Post subject: Reply with quote
as an emergency replacement then these might work ..
https://www.amazon.co.uk/Miniature-Female-Spade-Terminal-Connector/dp/B00B7FKVK6
try google and see if anything is available .. if not your into OPC and what they can supply ..
if you have any part of the connection still viable then its a case of new pins only for the wiring if you can source them .
ill check at work tomorrow to see if we have anything but im afraid i think not as i've just sorted our wiring box and i don't recall this plug in their.
Indy Mechanic .
PostPosted: Wed Aug 07, 2019 4:47 pm    Post subject: Reply with quote
Thanks for the advice, I had reached the same conclusion late last night but did not have enough connectors. Bought some more, fitted them and all is well.
I just need to get a proper plug now so that when I trade in..... the old plug got too damaged to be reused. But, now that I have some time I will just have to keep looking at all the possible websites.
Thanks for your time in responding.
P9XX
PostPosted: Wed Aug 07, 2019 5:58 pm    Post subject: Reply with quote
I think this may be MAF female connector (compared to mine). For the money, it's worth a try.
https://www.ebay.co.uk/itm/1928403738-936062-1-5-WAY-CONNECTOR-KIT-Inc-Terminals-and-Seals-5-AC073/233073169592?hash=item36443e54b8:g:ixgAAOSwmkBcJ2PK
2008 997.2 C2S PDK Basalt Black
PostPosted: Wed Aug 07, 2019 6:32 pm    Post subject: Reply with quote
If the connections in the old plug are ok .. i suspect they will be then the link from P9XX seems to be the correct plug .. just a case of removing the old connectors .
I can say that for removing electrical connections on a Porsche then this is a an excellent set ..
https://www.ebay.co.uk/itm/23-Car-Electrical-Terminal-Wiring-Crimp-Connector-Pin-Remover-Extractor-Tool-Set/392102312666?hash=item5b4b1e7ada:g:TcIAAOSwvjdZRiiS
I had a good look at work .. the connections i might have but not the plug i'm afraid .
Indy Mechanic .
PostPosted: Wed Aug 07, 2019 7:47 pm    Post subject: Reply with quote
Brilliant guys thanks a lot. I agree the plug looks like the perfect match. I also noticed on the website that for an extra fee (£1) they will supply it with tails. So I'll take the easy option.
Absolutely brilliant, my first piece of luck for days! One question, P9XX, how on earth did you find this? I have been looking for days, websites, stockists visits, phoning Bosch, you name it I have tried it and got nowhere.
P9XX
PostPosted: Wed Aug 07, 2019 8:42 pm    Post subject: Reply with quote
How did I find this connector.
A bit of luck and a bit of determination.
Try searching for "Bosch MAF Sensor Connector" on Ebay.
Then search the AutoClick shop for 5 pin connectors. They have 29 variants but only 1 looks like the one on my car. The only doubt I have is that no dimensions are quoted + the unseen side on their picture should have a semi-circular cut-out to match the sensor. A quick telephone call to them and they should be able to confirm the cut-out and suitability.
Good luck with the repair, let us know if you're successful.
PostPosted: Thu Aug 08, 2019 7:06 pm    Post subject: Reply with quote
If ever anyone deserved this from me then its you ... worship
Credit where it's due i feel !
Indy Mechanic .
jl-c
PostPosted: Thu Aug 08, 2019 7:40 pm    Post subject: Reply with quote
another option for connectors:-
https://www.alibaba.com/product-detail/Free-samples-High-Quality-electrical-car_60701433173.html
PostPosted: Sun Aug 11, 2019 6:57 pm    Post subject: Reply with quote
Hi guys, just thought I'd let you know, the connector arrived an Saturday and is a perfect fit, so £900 saved and I feel a bit less silly for making such a basic error in the first place.
Now I need to start searching for a replacement waterproof rubber boot to cover the connector so that nothing looks different.
PostPosted: Sun Aug 11, 2019 7:43 pm    Post subject: Reply with quote
If a Mechanic tells you he doesn't make mistakes then he is a liar .. S*%T happens .. mistakes happen so don't worry about it .
If it can be repaired then that's all that counts .
Indy Mechanic .
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Tue Aug 13, 2019 2:15 am    Post subject: Reply with quote
This thread got me looking for a new MAF boot as mine has a split, I searched various places and you can get an angled one from the U.S. but there is something similar on eBay but it isn't angled unfortunately but may be fine for your application.
https://www.ebay.co.uk/itm/Bosch-Waterproof-Boot-for-5-Way-AMP-Superseal-JPT-Electrical-Wiring-Connector/130928490944
This is the PDF I found, you need long tail 90 degree boot, page 27 of the document.
https://www.is-rayfast.com/pub/media/pdfs/HarnessComponents.pdf
PostPosted: Tue Aug 13, 2019 7:15 pm    Post subject: Reply with quote
Thanks for this update, what a great community. A quick glance at page 27 and I am unsure as the boot has circular openings at both ends. I'll look more closely later.
As it happens I do have a superseal boot, unused, as I wanted to keep it looking as original as possible for trade-in value but having looked I actually prefer the straight superseal boot as it keeps the part well away from the belt.
