991 : 2011-2019 0
997 : 2004-2012 1
Boxster : 1997- 22
Cayman : 2005- 14
SJD
PostPosted: Mon Aug 05, 2019 11:05 am    Post subject: Ticking Noise at Idle Reply with quote
I have lived with an annoying ticking noise at idle for some time now.
I read in another post a response from deMort. As ever when such wisdom is shared I pay attention. Ticking noise at idle - brake booster / tandem pump... is this the same for a Gen 1?
I have a 2006 C4S. And before others wade in, it’s not associated with bore scoring. The tandem pump was replaced just over 5 years ago and the engine has had a FULL Hartech rebuild, all 6 cylinders soon after with only 24k miles on the clock. I had a new timing chain installed as ‘betterment’ during the rebuild.
Occasionally the ticking noise at idle isn’t there but majority of time it is. Car is now on 39k Miles. It doesn’t use oil and is religiously warmed up before any spirited driving.
I read info about chain tensioners and that there is little can be done to sort the ticking. Sticky hyd tappet has also been suggested.
Any advice on how to narrow this down without spending a small fortune “troubleshooting”?
PostPosted: Mon Aug 05, 2019 4:03 pm    Post subject: Reply with quote
Thats a rare fault and Gen 2 only .. it's a possible but highly unlikely fault based on that one post which was more related to the debris in the oil filter Smile
My guess is a sticking tappet due to the intermittent nature you have described .
Sound clip of it if possible with you walking around both sides of the car at the rear please .
timbo1811
PostPosted: Mon Aug 05, 2019 7:06 pm    Post subject: Reply with quote
I had a Boxster with a ticking noise you would have sworn was a tappet, turned out to be a loose plug.
Lotus Elan, Lotus Elan +2, MGA Mk11, TR4, 230 Compressor, 320 coupe, 944, Boxster 2.7, 997.1(current), VFR 1200, CBR 1100 Blackbird
bazhart
Approved Trader
PostPosted: Wed Aug 07, 2019 5:48 am    Post subject: Reply with quote
We have posted various long and detailed replies about this problem that has many sources and sometimes cannot be found whatever you do, spend or replace.
Regarding the intermittent nature of the sound coming and going - there is another possible explanation. The engine management system slows down the tickover when the engine warms up and as it gets hotter and has several different speeds it lowers the revs (8 or 10 choices I think) - without showing it on the rev-counter.
So when you leave it ticking over the coolant temperature rises and falls as the fans kick in and out and sometimes results in the tickover speed dropping too low and resulting in this typical hydraulic tensioner weakness creating cam chain snatch causing the tick.
The tickover speed is detected once/rev so the engine can "hunt" at low revs between firing cylinders as it tries to balance slightly different individual cylinder performances at such small fuel delivery speeds and can result in the tickover being too slow as it tries to balance itself.
As we are in the hot weather I would check the radiator fans are working (or working soon enough) as this can influence that whole scenario.
Baz
Click here for the Hartech
www.hartech.org
SJD
PostPosted: Wed Aug 07, 2019 7:09 am    Post subject: Reply with quote
Thanks for all the feedback.
I’m struggling to upload a video clip, keeps coming up with “no post mode specified”?!?
Any ‘how to guides’ for a techno phobe?
318touring
PostPosted: Wed Aug 07, 2019 8:30 am    Post subject: Reply with quote
Why don't you just upload it to youtube, and post the link here?
If you are using gmail and already logged in, go to youtube in a new tab. Upload it using their 'studio' or something. Really painless and effective.
PostPosted: Wed Aug 07, 2019 6:34 pm    Post subject: Reply with quote
It has to be done via you tube , send me the file if you wish and i'll upload it and post it here .
De.Mort@virginmedia.com
SJD
PostPosted: Thu Aug 08, 2019 5:17 pm    Post subject: Reply with quote
I’ve sent you a couple of emails. See what you think. Thanks!
PostPosted: Thu Aug 08, 2019 5:50 pm    Post subject: Reply with quote
Videos uploaded for others to comment on ..
https://youtu.be/NEITqYOIrH8
https://youtu.be/Kk55VIuDAQQ
GMG
PostPosted: Thu Aug 08, 2019 6:41 pm    Post subject: Reply with quote
...sounds pretty normal to me...these are noisy , mechanical engines which tend to amplify their internal workings owing to their flat configuration...
Mine has had £14k's worth of rebuild and sounds similar from memory; hardy ever drive it sadly...
Of course phone microphones do exaggerate the sounds recorded...[/list]
GMG
PostPosted: Sat Aug 17, 2019 6:51 am    Post subject: Reply with quote
...tbh I was surprised this post didn't receive more interest given the general anxieties around these engines...
Did you seek a view from a Porsche specialist?
me&my997
PostPosted: Sat Aug 17, 2019 7:37 am    Post subject: Reply with quote
Normal Surprised it don't sound like my 997 C4 Confused if that is normal then i'm happy mine isn't
964 C2 / sold in haste - 2010
996 C2 / bought in haste - 2011
997 C4 / back in the game - 2019
http://911uk.com/files/dsc_5307_2_764.jpg
https://www.instagram.com/andy911wheels/
me&my997
PostPosted: Sat Aug 17, 2019 7:38 am    Post subject: Reply with quote
In the first clip the noise quickens with the increase in revs ,
If it was something just affecting tickover then that can't be right .
GMG
PostPosted: Sat Aug 17, 2019 8:28 am    Post subject: Reply with quote
...full hartech rebuild thus probably as baz has indicated; some just make a noise ? Are noisier than others...
Mine was serviced recently by Williams Crawford a very well respected Porsche Independent whom raised no issues stating mine was exemplary...
timbo1811
PostPosted: Sat Aug 17, 2019 1:13 pm    Post subject: Reply with quote
I'm sorry but that doesn't seem right to me... especially as it was rebuilt not so long ago.
alpinaman
PostPosted: Sat Aug 17, 2019 2:18 pm    Post subject: Reply with quote
Thats not "normal".Its an awful noise.
I sounds like collapsed lifter(s) to me.
monster
PostPosted: Sat Aug 17, 2019 4:40 pm    Post subject: Reply with quote
A blowing exhaust can sometimes make a similar sound....
me&my997
PostPosted: Sat Aug 17, 2019 4:44 pm    Post subject: Reply with quote
Have you listened to the clips Surprised
jl-c
PostPosted: Sat Aug 17, 2019 5:51 pm    Post subject: Reply with quote
You'd be suprised, a manifold crack can sound just like that, however I agree, it doesn't sound right.
PostPosted: Sat Aug 17, 2019 6:48 pm    Post subject: Reply with quote
I answered via email my thoughts on this .. to be fair ill post it here ..
I've just uploaded the videos and posted them on the forum for others to
comment on ..
For me .. that's not a tappet sticking .. it does sound more chain related
, a little louder than i would have liked .
It seems to be more bank 2 so the o/s/r of the car .. it would be worth just
making sure all the plugs are tight on that bank as was mentioned on your
post .
I do know that rebuilt engines can have a chain type noise and there isn't
anything you can really do about it .
As with all videos of noises it may well be louder or quieter in real life
than the recordings shows , as such i would like , when ever you get the
chance just to get an Indy to have a listen and confirm its not a problem .
lets put it this way .. i have in the past told one guy not to start his car
again and to get it recovered on the forum .. with you its a noise I'm not
worried about as such but would like someone to listen to the car instead of
remotely like i am.
Basically it needs to go on a ramp and confirm the noise is from the
tensioner area that side .
i've not had a reply so can't comment further and my " help " wasn't that good .. . i don't have an answer basically .
