997 : 2004- 63
Carrera SC : 1977-1983 3
Boxster : 1997- 25
Cayman : 2005- 20
Cayenne : 2003- 7
Jt911c4s
PostPosted: Sun Aug 04, 2019 2:24 pm    Post subject: Hello from a 997.1 C4S newbie Reply with quote
Hi Everyone,
I’ve finally managed to join the Porsche club, and bought a 56 plate 997.1 c4s 93000 miles. Decent history, the motor sounds good, but like any car this age with a number of things to do.
What I’ve done so far:
- New Bridgestone tyres all around
- New pads all around - the discs look good
- New LUK clutch and DDFlywheel (plus bearing seals - there was a small oil leak)
- New slave cylinder
- New battery
- New pass side A/C condenser (rad)
- Ran a RedX fuel fuel system cleaner additive through the fuel, and it has made the car a lot nippier - I wonder if it will stay like this or just when the additive is in there.
- Oil change (since the oil change, the oil pressure seems to fluctuate when the car is warm and idling between 1.5 to 3. Is this normal? Otherwise the pressure seems to read normal when the engine is revving)
The previous owner had a K&N intake system fitted (filter and breather assembly - plugged in) and has done something to the mufflers because i
I can see a cut/weld on the sides and the exhaust sounds more like a Ghundo hack exhaust.
Tomorrow I am getting a proper 4 wheel alignment.
I suspect things that may need doing in the near future:
- new shocks all around
- something around the injectors (maybe at least remove, clean and put back in?) has anyone done this before, any advice?
- Outside: deep wax on the main body and seal, bumpers re-sprayed
- Inside - leather recondition. (Does anyone have any experience with getting scratches out of the leather somehow? I wonder if there are any indy’s Out there that can recondition the interior?
- radio upgrade to something modern with apple car play. Can anyone recommend anything?
Otherwise the car seems good, more wear and tear niggles inside.
Is there anything else I should watch out for or plan to do/check in the near future? I plan to change the oil every 5-7000 miles.
me&my997
PostPosted: Sun Aug 04, 2019 2:42 pm    Post subject: Reply with quote
Nice buy , early days with my 997 C4 but loving it so far .
If yours hasn't had the MAJOR 12 yr service done then i would look to get on top of the recommended items within that , maybe not all at once but certainly worth the attention over the coming year
Items include
drive belt
brake fluid
awd fluid
plugs
cabin filter
service & all points inspection
964 C2 / sold in haste - 2010
996 C2 / bought in haste - 2011
997 C4 / back in the game - 2019
http://911uk.com/files/dsc_5307_2_764.jpg
https://www.instagram.com/andy911wheels/
PostPosted: Sun Aug 04, 2019 2:54 pm    Post subject: Reply with quote
Lowe temp thermostat and Millers nano stuff oil to reduce the risk of bore scoring.
Jt911c4s
PostPosted: Sun Aug 04, 2019 4:19 pm    Post subject: Reply with quote
Items include
drive belt
brake fluid
awd fluid
plugs
cabin filter
All done thankfully by previous.
John
911-997-C4S Gen1 07MY
me&my997
PostPosted: Sun Aug 04, 2019 6:14 pm    Post subject: Reply with quote
Been using Millers for over 10 years in both weekender & daily drive but in real world use is the lower temp thermostat really worth doing ?
Accepted if occasional track days are planned or perhaps long touring days in hot climate its a worthwhile consideration but is it really a necessity for the average user ?
PostPosted: Sun Aug 04, 2019 6:24 pm    Post subject: Reply with quote
Errr......100%! That's unless you want to run a higher risk of scoring bores.
Have a good read up on here how bores get scored and under what conditions and also what a LTT does to reduce the risk. Scoring isn't just caused by giving the car a thrashing over a period (eg. trackday).
Start here: http://911uk.com/viewtopic.php?t=65761
