997 : 2004- 62
Boxster : 1997- 26
Cayman : 2005- 20
Cayenne : 2003- 4
BobbyT
PostPosted: Sat Aug 03, 2019 9:29 am    Post subject: Air Con recommendation Reply with quote
The time has come to get the air con on Lola sorted out.
Jaz in St Albans look after the old girl and have recommended Alpinair (http://www.alpinair.co.uk/classic-vintage-cars/)
Just wondering if anyone has used them
Bob
1997 - 993 C4 - Ocean Blue
Endoman
PostPosted: Sat Aug 03, 2019 10:10 am    Post subject: Reply with quote
Replaced the complete system last year.
If the evaporator has gone the work involved will take a long time so be prepared for a big bill. https://www.pelicanparts.com/techarticles/Porsche-993/65-ELEC-Evaporator_Replacement/65-ELEC-Evaporator_Replacement.htm
I did most of it myself with the help of Jim @ Chillout took a week.
PostPosted: Sat Aug 03, 2019 10:24 am    Post subject: Reply with quote
Given that age of these cars you really need to change the evaporator as it's unlikely to have been done. Prepare yourself for 10hrs labour cost on a part that costs less than £150 Surprised
It's not difficult just time consuming so it might be worth approaching an Indy that has done this work before and see if they will come up with a deal. After you've had a leak test to see where the actual problem is.
The game's afoot. It's time to put a bit of (Colini) stick about......"Shall I open her up Miss Jones and show 'em a clean pair of heels?" "Do you think that's wise Mr Rigsby this is a very old car"
johne
PostPosted: Sat Aug 03, 2019 10:47 am    Post subject: air con recomemendation Reply with quote
a question for tore really if he is still around. car was regassed 2 years ago .the air con has not worked since I bought the car . some one suggested I had a leak .so this week on the service I asked for a regas . my good friend Harvey (Porsche expert) said I had not lost any gas so no leaks and was running 3 degrease at the condenser so should be nice and cold .but as soon as I put the aircon on the flap seems to close .just was wondering if theres any suggestions as my friend is going to have a go at it in a couple of weeks
decgraham
PostPosted: Sat Aug 03, 2019 11:11 am    Post subject: Re: air con recomemendation Reply with quote
Silly question I'm sure but you have got the sliders in the right place?
If you've got 3°C at the condenser or evaporator? You should be good.
ATB Smile
BobbyT
PostPosted: Sat Aug 03, 2019 9:08 pm    Post subject: Reply with quote
I know less than nothing about the technicalities so am going to have to outsource the whole job. Problem I suspect is going to be mission creep, whilst its in pieces may as well (fill in the blank).......
Any recommendations of an indie to do the work gratefully received. Although I will pop down to Alpinair seeing as Jaz have recommend them.
B
ps plans for a boxster this year been put on hold pending £££ on the above Sad
LondonRob
PostPosted: Sun Aug 04, 2019 2:36 am    Post subject: Re: Air Con recommendation Reply with quote
Bob
I used Alpinair a few years back to repair a leak on an AC pipe under the sill covers. They've been in the business for years and had a couple of Porsches and other classics in for work when I visited. I'd recommend them.
ToreB
Approved Trader
PostPosted: Sun Aug 04, 2019 7:18 am    Post subject: Re: air con recomemendation Reply with quote
[quote="johne".but as soon as I put the aircon on the flap seems to close[/quote]
With A/C on, low CCU temperature setting, and the cabin is hot, the CCU will use resirculation to get to the desired temperature as fast as possible. All fan air is then drawn through the resirc opening. If this fails to open due to a vacuum leak or diconnected vacuum hose, the air flow will be drastically reduced once the fresh air inlet closes.
See my DIY pages for details and test procedures:
https://www.bergvillfx.com/porschehvac1
Cheers,
Tore
'95 993 C4
Bergvill F/X
Porsche electronics specialists, products and repair services.
BobbyT
PostPosted: Sun Aug 04, 2019 5:22 pm    Post subject: Re: Air Con recommendation Reply with quote
Bob
Thanks Rob
johne
PostPosted: Mon Aug 05, 2019 7:29 pm    Post subject: air con recommendations Reply with quote
thanks tore
Leosayer
1996 Porsche 993 Carrera 2
PostPosted: Sat Aug 10, 2019 7:28 pm    Post subject: Reply with quote
I used Alpinair back in 2014 to fix my AC that wasn't holding gas.
They replaced the evaporator which cost around £1k. Can't fault the service or the quality - it's still working now.
Whilst my car was there, they had a beautiful old Maserati and (I think) a pre-war Bentley both for air-con retrofit.
1996 C2 Coupe, Polar Silver, Manual
