997 : 2004- 56
Carrera SC : 1977-1983 3
Boxster : 1997- 24
Cayman : 2005- 22
Cayenne : 2003- 7
PostPosted: Fri Aug 02, 2019 7:57 pm    Post subject: Gen 2 coils and spark plug tools req. Reply with quote
A couple of pictures of a gen 2 cayman plug job , going to do a write up on that in a few days ..
This shows the type of coil fitted to gen 2 997 and so on .
As you can see it's totally different and whilst they occasionally fail it's not a case of replacing all of them .
These basically don't corrode so there is no need .
These plugs protrude much further into the cyl and as such carbon up on the threads .. you have to force them out or wind in and out to free them off .
The tools shown .. a god send .. trust me .. the angles you can achieve make it simple on any model from a 993 upwards .
This is what i use every day .. the flexible end means easy access .
These are snap - on btw and i highly recommend something similar .
For a Cayman then its plenty of extensions .. but that's for the Cayman section.
Indy Mechanic .
 Filesize:  426.17 KB
 Viewed:  1150 Time(s)
 Filesize:  510.37 KB
kas750
Shanghai
2006 Porsche 911
PostPosted: Fri Aug 02, 2019 8:19 pm    Post subject: Reply with quote
chunkymonkey1982
PostPosted: Mon Aug 05, 2019 2:55 pm    Post subject: Reply with quote
Thanks for this Demort, I’ll be doing the same soon. Do I see bumper screws? Did you remove the rear bumper to change the plugs? I would think it makes life much easier...
PostPosted: Mon Aug 05, 2019 3:51 pm    Post subject: Reply with quote
Gen 2 997 ..
You need to remove the rear bumper , then the silencers then the heat shields.
The main reason is you often have to cut off the x2 sleeve clamps to remove the silencers .
The instructions just say remove the silencers with the bumper in situ ( on a ramp ) .. in reality it's not really possible if doing it jacked up and with these sleeve bolts corroded .
Indy Mechanic .
PanozGTR
PostPosted: Mon Aug 05, 2019 4:39 pm    Post subject: Reply with quote
Ian(Demort) Changed a coil pack and spark plug for me about a month ago and I was shocked at the amount of strip down involved. I would leave it to the professionals if I were you.
2009 997.2 C2S Macadamia/Cocoa
Sold,
Audi B8 S4
Subaru WRX Impreza
BMW E30 M3
Alfa Sud
Swampy
PostPosted: Mon Aug 05, 2019 4:51 pm    Post subject: Reply with quote
Nice one DeMort, as you know i had a misfire recently on no1 and the heatshields were a bit corroded, DeMort recommended that I should replace just the one coil pack along with the plugs, but I decided to replace all 6 coil packs and heat shields because I didn't want to take a chance of the other 5 failing.
That was around 8 weeks ago and no problems since, so thanks again DeMort..
A happy Swamps Smile
Swamped By Swampy Smile
PostPosted: Mon Aug 05, 2019 5:26 pm    Post subject: Reply with quote
This post was mainly to show the actual coils and how different they are to the early ones .
They just don't corrode basically .
Like anything though they can fail but i only recommend a single replacement .. replace the part that's broken ..
It's just a recommendation though .. people can replace all of them if they wish for peace of mind .
Swamps Thumb
With PanozGTR's car then we went with one and it's been fine since .
Also .. and i cant state this enough .. the plug socket and ratchet are a godsend for fitting plugs in All Porsches so well worth getting this flexi type if your a hands on person.
Indy Mechanic .
