Boxster : 1997- 25
pietrzj
PostPosted: Thu Aug 01, 2019 7:47 pm    Post subject: Spoiler curtain repair job - Easy DIY Reply with quote
Here is how I did it. It took about 20min and was really easy...
Raise spoiler about 3/4 of the way up. From the rear (I started on the RHS) Carefully push forward the curtain at the top corner. This was stiff and I used a small flat head screwdriver to pry it off. Then run the round shaft of the screwdriver along to the LHS, being careful not to fowl anything on the side you can't see. Then release the middle part of the curtain on both ends by prising the plastic channel under the small metal pins on either side. This needed some downward pressure while prising. The U channel that clips along the long horizontal metal rod just pulls away inch by inch, but again start by prying with a flat tool. Finally the bottom edge can be detached along with the rubber strip by pushing forward the rubber with a flat head screwdriver or pry tool. The whole thing is then teased out under the metal rod towards the rear of the car. Slide out the rubber strip, clean up with soapy water and re-attach to the new curtain. Clean up the horizontal metal rod the U channel sits on and aply a thin coating of silicon grease (this fixed a grating noise I had for years which I assumed was the motor bearing - that I changed for no reason). Feed the new curtain in from the rear under the rod and attach the top part first. You can push into place by feeding your arm through the gap under the spoiler from the rear window. Then clip the U channel over the metal rod inch by inch and carefully snap the upper channel under the two metal pins either end (the new curtain clicked under much easier than the old one came off). The bottom rubber strip then gets pushed on from under the spoiler from the window side. Make sure this is all the way on by looking from the side of the car roughly eyelevel with the rubber strip. It took me about 15min to remove and 5min to refit, not including cleaning and lubricating. Easy (even easier if you have long skinny arms).
Jan
Now for the photos...
 Filesize:  644.77 KB
 Viewed:  1141 Time(s)
pietrzj
PostPosted: Thu Aug 01, 2019 7:49 pm    Post subject: Reply with quote
running along
 Filesize:  545.18 KB
 Viewed:  1138 Time(s)
pietrzj
pins
 Filesize:  288.61 KB
 Viewed:  1136 Time(s)
pietrzj
PostPosted: Thu Aug 01, 2019 7:51 pm    Post subject: Reply with quote
pin
 Filesize:  679.27 KB
 Viewed:  1134 Time(s)
pietrzj
Releasing the "U" channel from the horizontal metal rod
 Filesize:  667.49 KB
 Viewed:  1130 Time(s)
pietrzj
PostPosted: Thu Aug 01, 2019 7:53 pm    Post subject: Reply with quote
Metal rod, cleaned up and greased
 Filesize:  536.1 KB
 Viewed:  1128 Time(s)
pietrzj
complete
 Filesize:  717.13 KB
 Viewed:  1126 Time(s)
wilsonny
PostPosted: Thu Aug 01, 2019 8:43 pm    Post subject: Reply with quote
thanks for sharing... something I'll no doubt be doing at some point...mine has the slightest tear at moment.
1996 C2 manual
AP90
PostPosted: Fri Aug 02, 2019 4:53 am    Post subject: Reply with quote
Thank you for posting this
Shedman
PostPosted: Sat Aug 03, 2019 7:48 am    Post subject: Reply with quote
I did mine too about a month ago. Took me about an hour and I’m not very patient so no pictures. It’s certainly a DIY. I did the front boot struts too, was much easier than I’d thought. Not done the engine cover struts yet, that seems more involved.
1997 993 Targa Manual
