997 : 2004- 58
Carrera SC : 1977-1983 3
Boxster : 1997- 27
Cayman : 2005- 22
Cayenne : 2003- 7
PostPosted: Mon Aug 05, 2019 9:29 am    Post subject: Reply with quote
What do you mean by shaft play?
cvega
PostPosted: Mon Aug 05, 2019 11:20 am    Post subject: Reply with quote
when holding the bearing by the housing one hand and shaft with the other, you can feel detectable movement of the shaft inside the bearing itself. Whether it's within specs, I don't know. While we were there replacing clutch and leaking IMS, was worth replacing, I think...
2003 996 C2 (Ohlins R&T suspension, Toyosport/Spyder exhaust)
PostPosted: Mon Aug 05, 2019 11:31 am    Post subject: Reply with quote
Ah, so you mean there was play in the bearing. Thumb
cvega
PostPosted: Mon Aug 05, 2019 11:32 am    Post subject: Reply with quote
Yes - sorry if I didn't describe it well. It didn't look bad but it made sense to replace it while car was in bits.
Dammit
PostPosted: Mon Aug 05, 2019 2:06 pm    Post subject: Reply with quote
Sorry- bit of a hijack, what's the opinion on the approach to the IMSB of making a small hole in the end of the IMS itself, and then replacing the standard oil pump drive shaft with one that has a groove in it to send pressurised oil to the IMSB?
PostPosted: Mon Aug 05, 2019 2:17 pm    Post subject: Reply with quote
For me the concept is a good idea but how this works in reality with regards to the (less) oil flow to the other engine components leaves it in a higher risk area potentially. Maybe this could be overcome with a better pump? Dont know
Dammit
PostPosted: Mon Aug 05, 2019 2:26 pm    Post subject: Reply with quote
It's a good question, I wonder how we'd answer it?
FWIW the (anecdotal) stuff I've been reading suggests that the pressure pump is pretty good, the problem with the oiling system is not to be found there, but rather with gravity uncovering the oil pickup, interrupting the supply to the pump.
But as I say, that's anecdotal.
I'm tempted to remove the seals from the large/final IMSB in the new engine and modify the IMS (AKA, put 2mm hole in the non-flywheel end), and machine a groove into the IMS-Pressure pump drive gear shaft.
PostPosted: Mon Aug 05, 2019 2:32 pm    Post subject: Reply with quote
If the engines in bits I'd just fit the later larger bearing and remove the seals. There's plenty of oil round that area to keep a frictionless bearing happy.
Dammit
PostPosted: Mon Aug 05, 2019 5:52 pm    Post subject: Reply with quote
I’m sure you are right, I just quite like the belt and braces approach of having pressurised oil going to the bearing.
However- unless we move the oil filter to a different place in the circuit that would mean supplying pressurised but unfiltered oil to the IMS.
Now this sounds bad, but bear in mind that the oil pump bearings are also fed the same oil.
PostPosted: Mon Aug 05, 2019 5:58 pm    Post subject: Reply with quote
Only solid bearings need pressurised oil. Frictionless bearings only need a light amount of lubricant.
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Mon Aug 05, 2019 6:04 pm    Post subject: Reply with quote
Dammit wrote:
. Unless we move the oil filter to a different place in the circuit that would mean supplying pressurised but unfiltered oil to the IMS.
Hmm, I hadn't thought about the filtering. Feeding the most delicate and vulnerable bearing with unfiltered oil doesn't sound good.
If the shaft is continuously under the oil lvl so that it will never drain out then in theory it would be possible...
You would be increasing the weight of the shaft and therefore the load on the bearings though .. i think that would be counterproductive to what you are trying to achieve .
If it isn't fully submerged then you would have a shaft half filled with oil at times .. that would cause an imbalance in rotation .
There is a very sizable amount of space inside the ims shaft to keep filled with oil .
Indy Mechanic .
PostPosted: Mon Aug 05, 2019 6:10 pm    Post subject: Reply with quote
I can't remember the exact application but I remember at work once having a problem with a roller bearing that was pressure fed with oil - think it slowed the machine down of something like that. The whole concept of roller bearings is to get away from pressurised oil feeds.
Dammit
PostPosted: Mon Aug 05, 2019 6:22 pm    Post subject: Reply with quote
Ok, I’m convinced- lets park that idea.
PostPosted: Mon Aug 05, 2019 6:29 pm    Post subject: Reply with quote
Can i just say .. even thought the idea is shelved ..
Alex .. worship
Oil as a lubrication is one thing but too much would act as a restriction .. it would need to be pushed out of the way by the ball bearings .. heat and a restriction would cause shaft rotational stress .
Spot on Thumb
Damn its always a learning day on this forum .
Indy Mechanic .
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Mon Aug 05, 2019 6:30 pm    Post subject: Reply with quote
The oil pump shaft has been known to snap so for me removing metal from it doesn't sit right with me (I fitted a billet drive shaft in mine) and I would want both the seals removed from the IMSB to let the oil flow through the bearing if I was to consider a modified shaft.
PostPosted: Tue Aug 06, 2019 8:52 am    Post subject: Reply with quote
Point 4 taken from here: http://www.petronomics.com/bear_mistakes.htm
With a circulating oil system, oil is pumped from a separate reservoir, where it cools down and lubricates simultaneously. The heated oil is then returned to the reservoir, where it cools down again. Filters in the system remove contaminants from the oil as it circulates. A circulating oil system can often greatly increase bearing life expectancy.
Circulating oil, however, should not be used in high-speed applications, such as machines tool spindles, because of unacceptable friction losses as the lubricant moves through the bearing. In these applications, only a small amount of oil is needed, and a spray-mist system is generally preferred.
Dammit
PostPosted: Tue Aug 06, 2019 9:39 am    Post subject: Reply with quote
Thanks Alex. Only question I have is what counts as high speed?
The IMS rotates at half engine speed IIRC, which would mean it would see ~4,200 rpm maximum in our engines, and a great deal less than that for 99.999% of the time.
What speed does a machine tool spindle rotate at?
PostPosted: Tue Aug 06, 2019 10:16 am    Post subject: Reply with quote
My milling machine does 3k rpm, lathe 1.8k rpm and surface grinder 3k rpm on their spindles.
Hertsdriver
2004 Porsche 997 Carrera 2
PostPosted: Tue Aug 06, 2019 10:41 am    Post subject: Reply with quote
Although I completely agree that an oil feed is unnecessary in this application, surely a car engine propelled IMS shaft isn't going to suffer from frictional losses if oil fed to a detrimental effect like an electric motor on a lathe (thats already geared up/down) where I could see drag becoming a problem on such a small powered motor to cause an issue in slow down. An internal combusion engine has a significant increase in power/torque to make that not an issue, or am I barking up the wrong tree?
Page 2 of 3
