997 : 2004- 58
Carrera SC : 1977-1983 3
Boxster : 1997- 27
Cayman : 2005- 22
Cayenne : 2003- 7
panda911
PostPosted: Thu Aug 01, 2019 3:23 pm    Post subject: Update on The IMS solution Reply with quote
Hi all
I posted a lot longer ago than I realised, in fact back in 2013, about the then newly introduced
The IMS Solution which Revolution Porsche (RP) agreed to trial on my car.
My 996/C4 is now on more than 90k miles and this is an update; Last year Gareth Merrick at RP mentioned that there was the most fine film of oil on the oil filter itself and he was reluctant to strip the spin on filter adapter from the oil filter boss as he needed to know the exact part number of the O ring sealing the adapter (provides oil feed to the new bearing) to the block.
As I was in US, I agreed to call same number I used to speak to Jake Raby in 2013 and the phone was answered by someone called Jud.
Jud said that he thought that the O ring was the Porsche part used with the original oil filter and would get back to me.
Within about 20 minutes I had an email reply from Charles L Navarro, (of LN Engineering) who gave me the Porsche part number for the O ring but also said that if we for any reason needed a new filter adaptor, he would send one.
Gareth replaced the O ring and the oil film disappeared and stayed disappeared..
I mention the above because I was impressed with the good customer service which LN Engineering responded.
I hope that this posting is helpful for anyone interested in this different approach to the IMS problem.
996mike
PostPosted: Thu Aug 01, 2019 6:18 pm    Post subject: Reply with quote
Very interesting
My ims solution for a 1999 3.4 c2 is to change the oil yearly
And then drive the wheels of it,,,,,,😎
Martin996RSR
PostPosted: Fri Aug 02, 2019 11:31 am    Post subject: Reply with quote
Me too - 1998 engine with 130k on the dual row bearing it started life with. Annual oil changes and drive it like I stole it.
PostPosted: Fri Aug 02, 2019 11:35 am    Post subject: Reply with quote
Just short of 140k on mine now. Makes 3 of us.
996driver
PostPosted: Fri Aug 02, 2019 12:37 pm    Post subject: Reply with quote
105k here on a 1998 C2. Here's hoping it lasts as well as the ones above!
Re IMS solution mentioned originally, any issues or feedback about how it operates?
1998 911 Carerra 2 Manual Coupe in blue
Previously :
1986 944 2.5 Lux
2001 911 Carrera 2 Manual Coupe in silver
https://porsche911owner.blogspot.com/
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Fri Aug 02, 2019 1:59 pm    Post subject: Reply with quote
130,000 miles on my engine now and i still have my original IMS bearing and it's in perfect condition, although I now keep it in a box in my garage.
PostPosted: Fri Aug 02, 2019 2:21 pm    Post subject: Reply with quote
Floor
PostPosted: Fri Aug 02, 2019 7:08 pm    Post subject: Reply with quote
40k mile Boxster in today with a failed IMS .. 987 .
Indy Mechanic .
kas750
Shanghai
2006 Porsche 911
PostPosted: Fri Aug 02, 2019 8:01 pm    Post subject: Reply with quote
3.2 S?
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Fri Aug 02, 2019 8:08 pm    Post subject: Reply with quote
I don't follow too closely as both of my non-Mezger ones are early engines, but is thar the single row or the later big bearing?
toddy2
PostPosted: Sat Aug 03, 2019 5:39 am    Post subject: Reply with quote
I’m on 140k original IMS going strong too. Yearly oil change.
Current Porsche Line up:
1968 911T
2002 996 4s
1988 944 (Sold)
skinny_monkey
PostPosted: Sat Aug 03, 2019 10:41 am    Post subject: Reply with quote
118k '99, all original.
Just done motorways, a roads, and 1-2 gear crawling along b roads with a 450 mile trip up to the peak district. No worries at all.
ScoobyDoo555
PostPosted: Sat Aug 03, 2019 12:24 pm    Post subject: Reply with quote
115k on mine - bearing was changed out at about 87k when Hartech rebuilt for piston slap (on a 3.4)
That's been a few years ago now - oil changed every year and driven in all manners of style Very Happy
Dan
Porsche 996 Carrera 4
Mods: "new car" magic tree. Pioneer F900bt, Alpine SPG10C2 x 4, JBL GTO 804 8" subs x 2, Shiny new rads & AC! Hartech-rebuilt engine & Sports exhaust
997 C2s discs. She stops quite nicely!
PostPosted: Sat Aug 03, 2019 3:58 pm    Post subject: Reply with quote
987 S 2005 Last of the early engines .
I've not seen one in a long time now .. this is the classic 13mm nut snapped off the bearing and dumped all its oil .
Back when these used to be a problem .. pretty much when i started on Porsche ( 2004 ) the classic sort of mileage always seemed to be around the 40k mark , not always but its a milage i saw a few times .
Strange this one was at this mileage as it would kind of indicate its milage not time based .
My own opinion is once passed this area of mileage then i feel there's very little chance of it failing ... as i said .. i've not seen one in ages now .
i only really know what i've seen over the years and am in no way an expert .
Indy Mechanic .
kas750
Shanghai
2006 Porsche 911
PostPosted: Sat Aug 03, 2019 5:03 pm    Post subject: Reply with quote
Yes presumed as much really Thumb
MisterCorn
PostPosted: Sat Aug 03, 2019 5:05 pm    Post subject: Reply with quote
Makes sense. I will be running the later big bearing in my rebuilt engines. Happy with the early dual row bearings. God knows why they changed it!!
Paynewright
PostPosted: Sat Aug 03, 2019 10:07 pm    Post subject: Reply with quote
Mine 996.2 C2 was swapped recently at 86k. In for oil leak / clutch and showed signs of play so done as a precaution. I asked for the old bearing back expecting some huge hunk of steel but its about half the size of a wheel bearing @ approx 40mm dia. Was shocked by the size and how much they cost to replace and how much catastrophe they can cause!
Sleep slightly better at night albeit replacement in situ comes with its own problems. Current plan is to run for 2 or 3 years (100k) and visit hartech.
PostPosted: Sun Aug 04, 2019 6:32 pm    Post subject: Reply with quote
I'm pretty sure the LH one is about £500 just to buy it from the company ..
You have to return to them the old one though as they warranty their bearing and wont do so if the old bearing has already started to break up and put metal into the engine .
My guess is you havent got this type .
Indy Mechanic .
wasz
Paul Ricard
1999 Porsche 996 Carrera 2
PostPosted: Mon Aug 05, 2019 9:22 am    Post subject: Reply with quote
Knocking on 139k miles on my dual row IMS, '99 3.4
It gets redlined every time I drive it and fresh oil every 6k.
996 parts cache sell off
cvega
PostPosted: Mon Aug 05, 2019 9:27 am    Post subject: Reply with quote
replaced my bearing with EPS at 145k. the original one had shaft play - but nothing too serious apart from ton of oil being dumped on it by leaking RMS
2003 996 C2 (Ohlins R&T suspension, Toyosport/Spyder exhaust)
Goto page 1, 2, 3  Next
Page 1 of 3
