997 : 2004- 56
Carrera SC : 1977-1983 3
Boxster : 1997- 24
Cayman : 2005- 22
Cayenne : 2003- 7
911DG
PostPosted: Thu Aug 01, 2019 7:41 am    Post subject: Coolant - quick question Reply with quote
Hi Guys
Sorry for the dull question but I’ve checked the boards and so much advise on coolant it’s confusing.
I checked my level this morning as hadn’t done it for ages and it’s just a tad below the Minimum line - maybe half an inch.
Is it best to just top up with 200-300ml of water or actually go and get the correct coolant and mix it etc etc ? Assume just a bit of water but wanted to ask. I opened it with engine cold.
Dan
Now:
- 997 C2S Cab (black on black on black)
Then:
- 996 C2 Cab (Black with Red)
- 996 C4 Cab (blue with grey)
- 993 C4 Cab (Black ith beige)
James M-S
2009 Porsche 997 Carrera 2
PostPosted: Thu Aug 01, 2019 6:01 pm    Post subject: Reply with quote
I was in a similar situation recently and just added water. You can buy distilled water cheap enough.
Check for spatter marks around the cap as the seal can fail. Monitor the level over the next few drives.
Frazerpart sent be my new cap promptly for a good price.
GMG
PostPosted: Thu Aug 01, 2019 7:05 pm    Post subject: Reply with quote
...also worth checking the small nuts atop the coolant reservoir tank vent aren't loose...coolant can escape from these under pressure...
PostPosted: Thu Aug 01, 2019 7:12 pm    Post subject: Reply with quote
The Porsche mix is 50/50 water / antifreeze which will give you a freezing point of about -31 degrees C.
With a total volume of approx 22 ltrs then 1 ltr of water won't dilute the mix very much .
Let's face it in this country then -20 C is plenty .
Modern antifreeze ( pink ) contains additives that stops small leaks .
Water or Distilled water .. now that's a question !
Also one i'm not getting involved in Smile
Indy Mechanic .
911DG
PostPosted: Fri Aug 02, 2019 7:06 am    Post subject: Reply with quote
Thanks guys ! Good advice.
Water vs Distilled water now that is a question ? For a coolant tank in a car - man I’d have never considered that for a second ........ I’d have just filled a bottle from a sink.
Does it Actually matter ???
Now:
Then:
darkhorse
PostPosted: Sat Aug 03, 2019 12:07 am    Post subject: Reply with quote
I have never used distilled water in my cars and never had corrosion or nay issues. I do maintain things pretty highly though. I imagine many garages dont use it either!
