997 : 2004- 56
Carrera SC : 1977-1983 3
Boxster : 1997- 24
Cayman : 2005- 22
Cayenne : 2003- 7
Marlon
PostPosted: Tue Jul 30, 2019 10:29 am    Post subject: Heated rear windscreen not working Reply with quote
Dash button lights up but clearly no juice going to the rear windscreen element, any suggestions before I get my Indy to take a look?
Cheers,
Marlon
jonno_
2005 Porsche 997 Carrera 2S
PostPosted: Tue Jul 30, 2019 5:04 pm    Post subject: Reply with quote
Have you eliminated the obvious - connector disconnected, fuse,any recent work that might impact it, replacement rear screen?
Have you checked with a voltmeter @rear window?
PostPosted: Tue Jul 30, 2019 5:53 pm    Post subject: Reply with quote
i would start by checking the relay and then the feeds to it .
85/86 feed / earth when switch pressed
30/87 feed and the output to the window .
Relay board is under the carpet and behind the rear seats .
Indy Mechanic .
 Filesize:  136 KB
 Viewed:  1086 Time(s)
 Filesize:  244.89 KB
Marlon
PostPosted: Tue Jul 30, 2019 8:38 pm    Post subject: Reply with quote
Thanks, I'm hoping its a simple fix - will take a look and if its beyond my skill level (which is very low Embarassed) I will mention it to my Indy Thumb
