997 : 2004- 58
Carrera SC : 1977-1983 3
Boxster : 1997- 27
Cayman : 2005- 22
Cayenne : 2003- 7
systech1
PostPosted: Tue Jul 30, 2019 8:49 am    Post subject: Brake Disk deglazing / honing required? Reply with quote
I'm replacing my standard Pagid street pads with Brembo HP2000 sport (mild track) pads.
The disks are standard Pagid drilled road disks, only a year old and look fine ....but do I need to deglaze or hone the disks for proper bedding in of the new track pads?
Any guidance would be appreciated Wink
Long time Porsche fan. Previous cars include 911T 2.2, 911E 2.2, Carrera 3.0, 986 Boxster S. Current car is 997.2S Manual (with PSE, H&S Backbox bypass, Sports Chrono, SSK, DSC PASM controller, Carrera Sports wheels, Ducktail/Diffuser and splitter, Sport Design steering wheel etc.)
Windy101
PostPosted: Tue Jul 30, 2019 9:29 am    Post subject: Reply with quote
When I change pad manufactures on race bikes I just give the discs a clean up using a scotch bright pad to remove old pad material from the discs.
diverzeusy
PostPosted: Tue Jul 30, 2019 11:25 am    Post subject: Reply with quote
a quick rub around with a piece of sand paper of some sort or emery cloth, you certainly will not harm them in this way and get a like new finish for your pads Thumb
jonno_
2005 Porsche 997 Carrera 2S
PostPosted: Tue Jul 30, 2019 5:06 pm    Post subject: Reply with quote
Might be worth checking / clearing the disc holes when you're at it 👍
