997 : 2004- 63
Carrera SC : 1977-1983 3
Boxster : 1997- 25
Cayman : 2005- 20
Cayenne : 2003- 7
Milo72
PostPosted: Sat Jul 27, 2019 8:08 pm    Post subject: Slow hot start... Reply with quote
So my cars on the button when cold, feels like it turns over twice before firing up. When it’s got though it has started to take a little longer, not horrendously bad but maybe 3 or 4 turns before it starts.
It’s had new coils in the last 3k miles and the plugs were done just before that. Any ideas ??
It’s a 997.1 C2S
Many Thanks
997.1 C2S Tip.
DucatiRob
PostPosted: Sat Jul 27, 2019 9:26 pm    Post subject: Reply with quote
Could be one of several things but it sounds like the cable to the starter/alternator, had the same problem with mine until I changed it earlier this year. Bit of a pig of a job to change and takes about half a day but not too hard. Could also be the starter motor or a corroded power distribution pin, easier to check this first before changing the cable.
Carrera C2S Manual-Full Hartech Rebuild-Ohlins R&T
Ducati 996
bullet-proof_biscuit
PostPosted: Sun Aug 04, 2019 5:46 pm    Post subject: Reply with quote
Does sound like the power cable also,
PostPosted: Sun Aug 04, 2019 6:12 pm    Post subject: Reply with quote
If it spins over slower when hot as opposed to cold then yup as above .. cable .
As you have a Tip i would suggest live with it for now .. it's an engine drop to replace it .
Indy Mechanic .
-- 997 --
PostPosted: Tue Aug 06, 2019 6:59 pm    Post subject: Reply with quote
Im having this same issue, starts sweet when cold but after when driving a while and its hot it starts slow !!! When i bought the car of the previous owner he had this particular cable changed, cable costed him approx £85 in 2015, my query is can this sort of thing happen again? Hasnt donevmuch mileage and isnt my primary car !! Wasnt there a cable upgrade available to eliminate this slow start when hot ???
Any other possibilities?? Front battery distribution pin and cable?
J
PostPosted: Tue Aug 06, 2019 7:13 pm    Post subject: Reply with quote
At the end of the day .. it's going to be a resisted starter lead .. causing poor voltage .. it's going to be a starter motor or it's going to be the power pin in the distributor box .. i could also say the earth side .. so battery lead and engine earth strap ..
check each one .
if the starter lead has been replaced then it's not that.
my guess .. starter motor .
Indy Mechanic .
