997 : 2004- 67
996 : 1997-2005 34
Macan : 2014- 6
NotoriousREV
PostPosted: Fri Jul 26, 2019 10:09 am    Post subject: Squealing window Reply with quote
My passenger window makes a horrendous noise when being raised or lowered but I can’t tell if it’s the seals or the regulator. The noise went away for a bit when I washed and waxed the car but now it’s back. Is it common for the regulator to make such horrible noise or should I be looking elsewhere?
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Fri Jul 26, 2019 11:12 am    Post subject: Reply with quote
I suspect the rubber seal.
Try this-
drop the window and pull the outside seal ‘away’ from the glass all the way along.
Give the rubber a good clean with water and washing up liquid
Clean the window thoroughly, ideally clay it and apply Rain X or some other glass sealant. Maybe worth doing the same to the inside surface too.
Mine still squeals in hot weather.
For best results replace the seal, but I think they are £££
EGTE
PostPosted: Sat Jul 27, 2019 9:14 am    Post subject: Reply with quote
Maybe this from the ever-reliable Scotty Kilmer will cure it?
https://www.youtube.com/watch?v=b1odBu9tNmY
NotoriousREV
PostPosted: Sat Jul 27, 2019 10:39 am    Post subject: Reply with quote
It never occurred to me that it was just the window against the inner seals. A quick wipe with silicon spray and they’re silent again! Thanks for the replies.
EGTE
PostPosted: Sun Jul 28, 2019 8:24 am    Post subject: Reply with quote
Scotty's a star.
S4ch
PostPosted: Fri Aug 09, 2019 10:44 am    Post subject: Reply with quote
Did the silicone spray yesterday and has definitely quietened down my squeaky windows.
wasz
1999 Porsche 996 Carrera 2
PostPosted: Fri Aug 09, 2019 5:00 pm    Post subject: Reply with quote
The outer seal gets the "fur" worn off it and then the rubber sticks making a squeek,
Eventually the rubber gets pulled in by the window putting horrific strain on the regulator
then your regulator fails.
I use autglym glass polish and gummifledge on the window seal, no more problems.
Or you can replace the seal (they are expensive).
