997 : 2004- 58
Carrera SC : 1977-1983 3
Boxster : 1997- 27
Cayman : 2005- 22
Cayenne : 2003- 7
Rosselder83
PostPosted: Thu Jul 25, 2019 7:48 pm    Post subject: 996 turbo turbocharger removal Reply with quote
The saga of my 996 turbo continues. Currently attempting to remove both turbos. I have the exhaust off but that’s proving to be the easy bit.
On the pass side the oil feed line and check valve actually came loose, everything else is proving difficult.
I see the route of the feed line on the drivers side so if I have to cut that I’m ok. What I’m not too sure about are the lines to and from the turbo sumps. I tried to drain them but both sump plugs are absolutely solid, the drivers side one just rounded and that was just from sheer force. My initial plan was to just unbolt the sumps from the turbos and leave them in place but that doesn’t appear to be a viable plan now.
So worst case I’m going to have to cut these sump lines as well. Can anyone tell me how much tears (both physical and financial) I’m going to shed here.
Also if anyone has any top tips I’m all ears. This car is fighting me every step of the way!
Rosselder83
PostPosted: Fri Jul 26, 2019 7:19 pm    Post subject: Reply with quote
So after some mild jabbing about the internet I found the following diagram, looks the the bottom two end up in each side of the oil pump held in by a bolt and two o-rings.
It’s not really clear how the top ones connect? Do they connect into the oil tank?
 Filesize:  69.75 KB
 Viewed:  2323 Time(s)
darkhorse
PostPosted: Fri Jul 26, 2019 10:54 pm    Post subject: Reply with quote
I have a 997t but have read of people having issues getting the 996 turbos off as well. This is the Porsche WM for the procedure on a 996t but it doesnt seem that amazing! They advise removing exhaust manifold, clearly they are assuming a new car and not corroded nuts lol
https://www.dropbox.com/s/chdwqv4tvjh6uez/996tremoveturbo.pdf?dl=0
As far as more relevant info try this https://www.6speedonline.com/forums/996-turbo-gt2/253730-turbo-removal-diy.html
Not sure about the oil line replacement, from the thread above it seems doable with the engine lowered (not removed, lowered)
hth cheers
Griffter
PostPosted: Sat Jul 27, 2019 7:17 am    Post subject: Reply with quote
I don’t have a 996T and I’ve never taken one apart, but reading that diagram as an engineer, the top pipes connect to each sump using a flange on the pipe and a union. Same sort of connection as a hard brake line to a caliper. If you can undo the union all the way (all you’ll see is a nut with the pipe going through it) it’ll disconnect itself!
Rosselder83
PostPosted: Mon Jul 29, 2019 11:36 am    Post subject: Reply with quote
Thanks for the input chaps, after studying the above diagram again i can see where the feed for the sumps attach to a T-Piece at the top of the oil tank.
Will go with that and see what happens
rgracin
PostPosted: Mon Jul 29, 2019 1:21 pm    Post subject: Reply with quote
I feel your pain.
A tip from me is if you are removing the two pipes numbered 16 in the diagram from the top of the oil tank, attach a piece of string to the end of the pipe, then remove the pipe with enough string still remaining at the top of the engine, so that you can pull the pipe (or attach to the new one if needed) back up through the same route. It will be hugely difficult to do otherwise.
Good luck
2003 Manual 996 Turbo
2000 986 Boxster S
2007 E63 AMG Estate
Rosselder83
PostPosted: Tue Jul 30, 2019 11:32 am    Post subject: Reply with quote
A great tip, thanks very much. Did you have to drop the engine a bit when removing these pipes and did any oil come out of the oil tank at that height?
rgracin
PostPosted: Tue Jul 30, 2019 1:17 pm    Post subject: Reply with quote
I did drop the engine a few inches to give room to get in there.
It's been a while, but I don't recall much oil coming out as they are at the top of the tank. I would put an old rag under the joint when removing just in case, but there wont be floods of it.
I presume the nuts on the turbo to manifold will be rusty blobs? If so a nut splitter and hammer and small chisel will be what you need. Don't waste time trying to undo them.
2000 986 Boxster S
2007 E63 AMG Estate
Rosselder83
PostPosted: Tue Jul 30, 2019 9:41 pm    Post subject: Reply with quote
All useful information mate thanks very much.
Yes those nuts are barely still classed as metal. Im currently in debate whether to remove them there or just take the manifolds off as those bolts are also in dire need of being updated. Bolts snapped in the head doesnt fill me with deep joy i must admit
plynchy
PostPosted: Wed Jul 31, 2019 8:19 am    Post subject: Reply with quote
I'd do the lot whilst you're on. Chap on here makes/sells Titanium studs to replace the std items, they are impossibly light Very Happy
I swapped out the manifolds on my old 986S and it's a bitch of a job laid on your back, got my Indy to do the 996T items at a very reasonable cost considering half of them sheared.
'02 996 Turbo Manual Coupe Lapis/Grey. Unlimited grins.
Rosselder83
PostPosted: Wed Jul 31, 2019 11:30 am    Post subject: Reply with quote
Titanium eh, sounds lovely. Any idea on who that is?
plynchy
PostPosted: Wed Jul 31, 2019 12:21 pm    Post subject: Reply with quote
Poppopbangbang is his username.
There was a thread in the for sale forum (I think) ages ago, but try dropping him a PM. He tends to be quite a busy chap though.
Edit: Thread here > http://911uk.com/viewtopic.php?t=110603&highlight=
Google: http://porschetistuds.co.uk/ thumbsup
HSC911 ended up going and collecting mine for me as he lives down the road from the guys workshop.
