chunkymonkey1982
- Joined
- 19 Jun 2017
- Messages
- 111
I have a 09 997.2 and noticed that if I park the car on a banked road ie the passenger or driver side is higher or lower then the other side when I start the car up there is a bit of smoke. No smoke if the car is parked on flat ground or if its parked with the engine lower than the front. I looked into this and apparently it could be caused by the AOS diaphragm failing. In my case I think its more linked to the design of the engine and isn't a big deal.
Do you think its worth replacing the AOS as a preventative action, its about £80 from design911 and I plan on taking the air box out and replacing the drive belt in the weekend anyway...
