997 : 2004- 58
Carrera SC : 1977-1983 3
Boxster : 1997- 27
Cayman : 2005- 22
Cayenne : 2003- 7
robbo666
PostPosted: Tue Jul 23, 2019 7:11 pm    Post subject: 996 exhaust silencer fitting Hertfordshire Reply with quote
Hi all
My 2 new silencers arrived today and I need to get them fitted.
Anyone got an approximate cost for this?
I have all the fixings so labour only.
Any recommendations for garages?
Thanks for any help.
jezgreen911
PostPosted: Tue Jul 23, 2019 8:19 pm    Post subject: Reply with quote
I've heard good things about AMS Porsche in Hitchin Thumb
2003 996 C2
robbo666
PostPosted: Tue Jul 23, 2019 8:26 pm    Post subject: Reply with quote
I'm near stanstead so on the Essex border.
I'm tempted to do it myself but wanted a rough idea of cost.
I'll call them tomorrow.
Cheers 👍
jezgreen911
PostPosted: Tue Jul 23, 2019 8:46 pm    Post subject: Reply with quote
I found changing my exhaust silencers pretty straight forward, yes you'll get a few stubborn rusted bolts but if your fairly competent with the spanners then I'd go for it thumbsup
2003 996 C2
996ttBULLA
PostPosted: Tue Jul 23, 2019 8:47 pm    Post subject: Reply with quote
https://www.porschacare.com/
Go see matt at Porschacare , i live in the same neck of the woods as you and hes the only guy to touch my car.
2003 996 Turbo
Aero Kit
Silver with black
Manual
M&M Cup Exhaust
Remap
890 clutch
964 RS FW
Forge DV's
997 SSK
and plenty more to come......................
robbo666
PostPosted: Tue Jul 23, 2019 9:00 pm    Post subject: Reply with quote
I might try, worse case I will have to drive to a garage with 1 silencer off 🙉....
robbo666
PostPosted: Tue Jul 23, 2019 9:05 pm    Post subject: Reply with quote
Thank you 👍
Hughb
PostPosted: Wed Jul 24, 2019 2:07 pm    Post subject: Reply with quote
jezgreen
you have changed the silencers.... I am contemplating the same ... I have engineering skills but not on cars .... having recently acquired my first 996 c2 2003 I am discovering, through forums like this that quite a lot of maintenance, improvement is entirely possible. in fact I am finding myself irresistably drawn to having a go!
My silencers are soon going to need changing and from an inspection underneath, from the block to the tips there isn't a recognisable nut or bolt that could be undone with a socket...they are all shot to pieces ...crumbled away .. I am surprised that the exhaust system is still attached frankly.
What slightly bothers me is that as I go to replace the silencers...
1) break the three studs undoing the three small nuts on the silencer mounting bracket (this is the way to release the silencer, it is said, rather than the vertical bolts) (this bracket is mounted on the block, isn't it?)
2) I disturb the manifold mounting on the engine block and then have a bigger problem in the form of up to 12 broken studs
Any comments/reassurance you can give? did you have to deal with broken studs ...eg on the cat to silencer flanges?
jezgreen911
PostPosted: Wed Jul 24, 2019 6:20 pm    Post subject: Reply with quote
This diagram should help, if necessary the bolts on the cat to silencer sleeve clamps can be cut off if they won't undo, as you can see the three bolts on the exhaust silencer bracket bolt to a hanger bracket, all six of my bolts came out ok but worst case scenario you could always replace the hanger Thumb
2003 996 C2
 Filesize:  252.17 KB
 Viewed:  1158 Time(s)
robbo666
PostPosted: Wed Jul 24, 2019 6:54 pm    Post subject: Reply with quote
I called Matt and he and he can fit them after his holiday.
I think I'll let him do it.
Thanks for the info.
Hughb
PostPosted: Thu Jul 25, 2019 8:45 am    Post subject: Reply with quote
thanks jezgreen .... for the diagram
I am relieved to see that the both sets of potentially problematic studs are 'downstream' so to speak..... namely that they come out with the bit that you are removing...
...eg the flange bolts come out with the cats
and
.... the hanger bolts come out with the exhaust brackets
so there is every chance of dealing with stripped threads/ broken studs on the bench rather than under the car!
