Boxster : 1997- 25
gunner
PostPosted: Mon Jul 22, 2019 10:07 am    Post subject: Sunroof motor cutoff Reply with quote
Closed my sunroof at the weekend and instead of the motor cutting out once it was fully closed it continued to run until I released the switch a second later. Made a horrible noise too.
I assume there is a cut-off switch somewhere which has failed and wondered if anyone has had the same issue?
993 C2 Tip Aventura
AndyS
PostPosted: Mon Jul 22, 2019 10:27 am    Post subject: Reply with quote
Not seen this issue, but just curious - is your switch permanently live?
i.e. does it still operate with ignition off?
Andy
gunner
PostPosted: Mon Jul 22, 2019 10:30 am    Post subject: Reply with quote
Pretty sure it doesn't work with the ignition off. Either way, it's only just started doing this.
993 C2 Tip Aventura
AP90
PostPosted: Mon Jul 22, 2019 11:39 am    Post subject: Reply with quote
Damn that's a pain, I guess there's a control system in the motor/mech you can access it via the zip in the roof, maybe have a fiddle/clean with the contacts and gear box
Yank site here https://www.pelicanparts.com/techarticles/911_sunroof_repair/911_sunroof_repair.htm
Haven't read through it but may be of some help, apparently mechs are the same for the older models and 993's??
Ash
akesanto
PostPosted: Wed Jul 24, 2019 1:19 pm    Post subject: Re: Sunroof motor cutoff Reply with quote
I have the exact same issue and since I just got the car was wondering if that's a feature. Apparently not.
Let me know if you find a fix for it, would love to know how to take care of this before the sunroof motor gets too damaged.
993 C4 (1995)
Instagram: instagram.com/alikesanto
