997 : 2004- 56
Carrera SC : 1977-1983 3
Boxster : 1997- 24
Cayman : 2005- 22
Cayenne : 2003- 7
tedzwedz
Location: Ladbroke Grove, London & North Yorkshire, & Isle of Carna - Scotland
1998 Porsche 996 Carrera 2
PostPosted: Sun Jul 21, 2019 12:55 pm    Post subject: Urgent help pls - sunroof stuck fully open! Reply with quote
Hi
As above, I've not used the car for a few weeks, I've opened the sunroof and it's now stuck fully open, all the way back.
When I pressed the shut button all it did was open more!!
Can you manually pull shut
Any tips, may rain soon! :-(
Best Edward
1998 Porsche 911 (996) C2 - GT3 SplitRim 18" Alloys, Oettle Porsche Sports Exhaust, K&N Airfilter, Silicone Cold Air Intake, Quad Exhaust Tips, Litronic Headlights (2008 - )
2012 Piaggio Vespa LX 125ie (way faster than the 911 around London!)
tedzwedz
PostPosted: Sun Jul 21, 2019 3:04 pm    Post subject: Reply with quote
I tried the emergency tool to close under the panal, would not turn
maph
PostPosted: Sun Jul 21, 2019 3:06 pm    Post subject: Re: Urgent help pls - sunroof stuck fully open! Reply with quote
tedzwedz wrote:
Hi
Motor sounds OK then so assume there is an issue with the switch itself. I am sure others will know more about what usually goes wrong with that and how to test it.
If you need to close it there should be a handle behind the trim that holds the sunroof switches/ interior light etc (is like this on a 997 and other cars I have had). If you can remove the trim and then the handle (prob looks like a big Allen key) you should be able to insert this into the motor and crank it closed manually.
If you have the owners manual it will give you details as to how to do it.
Edit...... looks like you have tried that. Has always worked for me. Sounds strange that the switch will open it further but you cannot manually crank it closed.
I guess you have eyeballed it all very closely to make sure nothing is broken on the cassette and there is nothing in there that should not be there?
2012 997.2 Turbo S - ES650
PostPosted: Sun Jul 21, 2019 4:40 pm    Post subject: Reply with quote
Try the below .. you have to press the allen key in , this disengages the drive so it will turn
You could also try comfort closing .. lock with the ignition key but hold it in the lock position to comfort close windows / roof .
Indy Mechanic .
 Filesize:  220.26 KB
 Viewed:  1028 Time(s)
 Filesize:  333.87 KB
 Viewed:  1055 Time(s)
tedzwedz
PostPosted: Mon Jul 22, 2019 5:55 pm    Post subject: Reply with quote
Thank you for your help guys!
The roof would not turn and the allen keys churned the metal, its whats called pot metal, i.e. v soft! Hopeless
I took motor off and cogs and manually wound temporarily!
PostPosted: Mon Jul 22, 2019 7:48 pm    Post subject: Reply with quote
I would humbly suggest you try the teaching process ... it's a pain and often has to be done several times ...i have no idea why it doesn't just work but its a pain in the ass to be honest ... if not then atm your into a new motor and this will also need calibrating .
re the gears .. you have to push upwards to disengage the gear from the motor .. i know full well from targa roof motors ( same thing ) they jam , don't release and strip the allen key fitting .. i have a draw full of old motors with worn gears , i swop these bits over as its common for them to fall apart on manual movement on the allen key part .. been there and done it many times .
just my 2 cents anyways .
Indy Mechanic .
