997 : 2004- 58
Carrera SC : 1977-1983 3
Boxster : 1997- 27
Cayman : 2005- 22
Cayenne : 2003- 7
beejay993
PostPosted: Sat Jul 20, 2019 9:33 pm    Post subject: Squealing Pagid Brakes C4S Reply with quote
Can anyone offer me some advise to remedy my dreadfully noisy brakes. When I bought my 4s the garage replaced the rear discs and pads with pagid parts. Ever since they were fitted they squeal really badly on braking. I’ve taken them all to bits, cleaned all parts, checked for glazed faces etc which was all fine. I’ve changed the vibration dampers to new ones and it’s still the same, albeit it went away for the first few drives after doing all this but has since returned. I did all the usual bedding in recommendations so I’m at a loss other than change the pads for an alternative manufacturer....it’s driving me mad !
Any suggestions on a remedy ? Cheers
993 C4s - Midnight blue
996 C4s - Arctic
997 Gen 1 Turbo
997 GTS
997 Turbo S - GT Silver
996 C4s - Polar
peterzoom
2001 Porsche 996 Carrera 4
PostPosted: Sun Jul 21, 2019 7:19 am    Post subject: Reply with quote
Have you taken the fronts off for a de-glaze also? Or are you certain it is only the the rears that are definitely making all the racket?
GT3 wheels, hub-centric spacers, brake ducts, Carrera rear wing, 200 cell cats+full big bore system, IPD plenum, K&N cold air intake, Hel lines, V3 sprit booster, Revo re-map, Numeric short shift, Rennline pedals, CSF radiators, Rennline semi-solid engine mounts, Alpine double din dvd, camera and speaker install, IMS Guardian and Zun-Sport grilles
Nightrain QDUN4
PostPosted: Sun Jul 21, 2019 7:20 am    Post subject: Reply with quote
I had Padgid discs and pads and they used to be very squeaky, still have the pagid discs and replaced the front pads with EBC red stuff, cleaned them all up with brake spray cleaner and used Cera Tec lube when reassembling them.
The squeak has gone and Very Happy and 2k in they are still silent, going to put EBC red stuff on the rear now as the brake dust reduction on the front is very noticeable and they work well for road use.
2004 C4S
Shurv
PostPosted: Fri Jul 26, 2019 1:04 pm    Post subject: Reply with quote
I fitted EBC discs and yellowstuff pads to a BMW Z4 a few years ago, they were truly awful, wooden, no feel whatsoever and the squeal from the pads was irritating. I tried all sorts of bedding in tricks but nothing ever worked,it has put me off aftermarket braking components. The only good bit was the lack of brake dust from the EBC pads.
996 C4S Arctic Silver Black leather
