997 : 2004- 56
Carrera SC : 1977-1983 3
Boxster : 1997- 24
Cayman : 2005- 22
Cayenne : 2003- 7
keendean
PostPosted: Sat Jul 20, 2019 8:17 pm    Post subject: Lack of reverse lights & water expansion level-997T Reply with quote
Recently had an engine out job by a specialist, who is not so close by.
I did have reverse lights and parking sensors, now no more. From searching on here, the fuse is B5 I think? But my side mirrors work, and I checked all the smaller 7.5a fuses which were fine. As I had a new clutch, I assume there is a sensor for reverse? If so, does anyone have a picture? I’m putting it up on a ramp on Monday at a friends, so will hopefully see something obvious.
Also, it looks as if my expansion tank was over filled, so will extract some when cold tommorow, I assume if it’s overfilled it must escape somewhere, as I had an amount on the floor under the expansion tank side. Anyone experienced this? I’m going to remove a small amount, drive and check, and hopefully will be the last coolant I’ll see under my car. Smile
jl-c
PostPosted: Sat Jul 20, 2019 9:01 pm    Post subject: Reply with quote
reverse switch
reverse switch
 Filesize:  96.28 KB
 Viewed:  680 Time(s)
