997 : 2004- 57
Carrera SC : 1977-1983 3
Boxster : 1997- 24
Cayman : 2005- 22
Cayenne : 2003- 7
crash7
PostPosted: Fri Jul 19, 2019 9:03 pm    Post subject: Instrument Cluster Wiring Help Reply with quote
I am looking to identify a particular cable that runs to the instrument cluster.
Within the multi-pin plug there are a host of cables and I want the one for the alternator/battery/charging light that shows up on the dash cluster.
Does anyone have a wiring diagram? or even better able to spoon feed me the information Very Happy
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Fri Jul 19, 2019 9:19 pm    Post subject: Reply with quote
Which model and year?
crash7
PostPosted: Fri Jul 19, 2019 10:02 pm    Post subject: Reply with quote
2001 C2 Thumb
kurlykris
PostPosted: Fri Jul 19, 2019 10:35 pm    Post subject: Reply with quote
Plug II white, pin 23.
I can`t get a decent screenshot of the whole page in the wiring diagrams that is readable when zoomed in.
I can email you the whole 996.1 wiring diagrams if you need them, about 7MB file size Thumb
2006 987.1 Boxster S 3.2 sport chrono
2010 Mercedes E350 AMG Sport
crash7
PostPosted: Sat Jul 20, 2019 8:52 am    Post subject: Reply with quote
Boom! - Many thanks Thumb
By chance do you know the location of a switched / ignition live that runs to the cluster, be it in the same or a different plug?
PostPosted: Sat Jul 20, 2019 6:28 pm    Post subject: Reply with quote
i use an Xps to Jpeg convertor program .. google it as there seem to be many ..
i open the wiring diagram , take a snapshot , right click and save as an Xps file in the print section instead of printing it .. i then use this convertor program to turn it into a jpeg ( picture ) .
Indy Mechanic .
PostPosted: Sat Jul 20, 2019 6:42 pm    Post subject: Reply with quote
I have a feeling RD/BU .. red/blue is the colour for an ignition feed .. fuse box by your right foot .. remove cover .. find this wire and test with a meter if its a 12v with ign on .. if so then solder a wire into it and run to the cluster .
either way a wire of size 2.5 - 4 mm is a main feed so just check these for a feed .. anything smaller will be an output so ignore these .
You should be able to check on the diagram Kris sent .
You will also need to fit an inline fuse when cutting in extra wiring.
Indy Mechanic .
kurlykris
PostPosted: Sat Jul 20, 2019 6:43 pm    Post subject: Reply with quote
Top tip Iain, is there no end to your talents Grin
And here is the converted pdf page to jpg Thumb
PostPosted: Sat Jul 20, 2019 6:50 pm    Post subject: Reply with quote
And that works perfectly Thumb .. open in a new image with chrome , select larger view with firefox .. etc etc ..
Thats it now .. i never need to post anything again Very Happy
Indy Mechanic .
